How is Gravitational Potential Calculated on the Moon's Surface?
  • Thread starter Thread starter Pho3nix
    Gravitation
The gravitational potential on the Moon's surface is calculated using the formula Vg = -GM/r, resulting in a value of -3.0 x 10^6 J/kg, where G is 6.67 x 10^-11 m^3 kg^-1 s^-2, M is the Moon's mass of 7.7 x 10^22 kg, and r is the radius of 1.7 x 10^6 m. The work required to remove a 1.5 x 10^3 kg spacecraft from the Moon's surface is -4.5 x 10^9 Joules, calculated using the potential energy formula Ep = GMm/r. The escape velocity, which is the minimum speed needed to break free from the Moon's gravitational field, can be derived by equating kinetic energy to the work done.
  • Understanding of gravitational potential energy (Ep = GMm/r)
  • Familiarity with gravitational potential (Vg = -GM/r)
  • Knowledge of kinetic energy (Ek = 0.5m(v^2))
  • Basic algebra for solving equations
  • Study the derivation of escape velocity in gravitational fields
  • Learn about the implications of gravitational potential in astrophysics
  • Explore the differences between gravitational potential on Earth and the Moon
  • Investigate the effects of mass and radius on gravitational calculations
Students in physics, astrophysics enthusiasts, and anyone interested in celestial mechanics and gravitational calculations.
Pho3nix
[SOLVED] Gravitation Problem
The moon has a mass of 7.7times10^22kg and radius 1.7times10^6m. Calculate:
a) The gravitational potential at its surface.
b) The work needed to completely remove a 1.5times10^3kg spacecraft from its surface into outer space.
c) What is the minimum speed which a body must have to escape from the moons gravitational field?
Vg=-GM/r
Ep=GMm/r
Ek=.5m(vsquared)
Vg is the gravitational potential
Ep is potential energy
a) Vg=GM/r
G=6.67times10^-11
M=7.7times10^22kg
r=1.7times10^6m
Plug in the numbers and I get -3.0times10^6
b)Ep=Gmm/r
M=7.7times10^22Kg
m=1.5times10^3Kg
r=1.7times10^6
Plug in numbers and get -4.5times10^9 Joules
c)In need help on this one.
Equate the KE to the work done in (b). That gives you the minimum v, which is called the escape velocity, which is the minimum speed that has to be given to the body remove it to infinite distance.
  • · Replies 39 ·
