The Bilinear Form Kernel in Mathematics
  • Context: Undergrad
  • Thread starter Thread starter Imparcticle
    English
The discussion revolves around the concept of bilinear forms and their kernels in mathematics, exploring definitions, analogies, and examples. Participants express varying levels of understanding and seek clarification on the topic, which encompasses theoretical aspects of linear algebra.
  • Some participants describe a bilinear form as an object that takes two vectors and produces a scalar output, using analogies related to food ratings to illustrate the concept.
  • Others argue that the kernel of a bilinear form consists of vectors that yield a zero output when combined with any other vector, emphasizing the need for precise definitions.
  • A participant questions the accuracy of the food analogy, suggesting that the kernel should not be viewed merely as vectors that cancel out in addition.
  • Several participants discuss the relationship between bilinear forms and matrices, noting that bilinear forms can be represented by matrices and that the kernel is related to linear maps derived from these forms.
  • There are mentions of specific examples of bilinear forms and their kernels, including trivial forms and forms defined by specific matrix structures.
  • Some participants express confusion about the definitions and properties of vector spaces, linear maps, and how these relate to bilinear forms and their kernels.
Participants exhibit a mix of understanding and confusion regarding the definitions and implications of bilinear forms and their kernels. There is no consensus on the best analogy to use, and several participants express differing views on the mathematical properties involved.
Some participants acknowledge gaps in their understanding of vector spaces, matrices, and the formal definitions of bilinear forms. There are unresolved questions about the transformation of linear maps into matrices and the implications of dimensionality in vector spaces.
This discussion may be useful for students and individuals interested in linear algebra, particularly those seeking to understand bilinear forms and their applications in mathematics.
I don't think you really want to know.
cookiemonster
A bilinear form is basically an object that "eats" two vectors and spits out a number. Imagine that the number produced is a "grade" that Mr. Bilinear Form gives to the taste of the vector combination.
The kernel is formed by all those vectors that totally kill the taste of the combination: when Mr. Form eats one of those, the combination gets a zero, no matter what the second vector is.
I don't get what u just said ahrkron, but thanks anyway.
Well, I'll try to simplify Ahrkron's "food" analogy:
Suppose I'm called a "billinear form". What I do is eat two different bits of food (these are the vectors) at the same time and then decide how much I like that particular combination and give it a rating (these are the real numbers). So, suppose I eat sushi and schnitzel at the same time. I like it a lot, so I give it a 106. Another time I eat pretzels and haggis at the same, but it's disgusting, so I give it a -34560. So those combinations I like better get a rating closer to positive infinity, and those combinations I like worse get a rating closer to negative infinity. The combinations that are right in the middle, the ones that I don't like or dislike, I give a rating of zero.
Suppose what I want to do now is find all those food combinations which I don't really like, but I don't really dislike either. I look through the ratings I gave the combinations and pick out the ones which have got a rating of 0. This is what the "kernel" is.
And no, it's definitely not Algebra 2.
- Warren
Just because I like making trouble for myself, what makes the combination=0? From your analogy, the output of the bilinear form is a scalar- not a vector, so the kernel is not just vectors that canceled from addition.?
Guess I should look this up, but I wonder if my reasoning is right...
Rachel
you aren't adding together the vectors in the algebraic sense of addition of vectors
A bilinear form on R^n, say, is given by an nxn matrix A, and the operation is b(x,y) = x^tAy for x,y column vectors.
stevo's interpretation of the kernel using the food analogy (which I dont' think I like, as it happens) is not accurate. If we must, then sometihng is in the kernel iff when we combine it with any other food substance, the answer is zero.
something, v say, is in the kernel of b(?,?) iff b(v,?) is zero for all possible choices of ? (note we are assuming symmetric so that this definition yields the same set as b(?,v) would do.
by fixing v we turn b into a linear map. the kernel is then the v that make this linear map the zero map.
Okay, I've jumped too far ahead. I understand part of what you're saying. I think I get the kernel part, but not the bilinear form part ;) I haven't read enough about vector spaces, matrices, or rings (for shame) to even think of an example of a bilinear form kernel- I can't see how the kernel can contain more than one v! Oh, so many questions, but, whatever, I'll work on it.
Thanks for trying
Rachel
Let b be the form on R^n given by B(v,w) = 0 for all W. The kernel is then all of R^n. Referred to the standard basis the form given by A = diag{1,1,1,1...1,0,0..,0} with p ones and q zeros has q-dimensional kernel. (you don't need to learn anything about rings or modules, it's simple (bi)linear algebra).
Okay, if you're willing, I'm able. Of the above, "= 0" was about all I understood. I just "learned" today what a vector space is (for shame;), so I will have to look up all of this and get past the language barrier.
Matrix A has only p 1s, and all the rest of the elements, (p*q)-p, are 0s.
The "n" in R^n and "q" in q-dimensional refer to the number of rows in the matrix.
If both of those statements are correct, I kind of get what you're saying. Even if "n" and "q" refer to "n*n" and "q*q" matrices I still kind of get what you're saying. (Which shows how much I get it.)
The biggest problem I have now is that I can't figure out how to transform a ?linear map? into a matrix- or whatever gets transformed into a matrix.
I see the relationship between
1)the ordered pair (x, y) from the cartesian product of the two domain vector spaces, say X and Y, AND the (row, column) coordinates of the matrix.
2)the value of the function at (x, y) AND the element at (row, column).
But my grasp of everything else is so tenuous, I can't get much of anywhere. For instance, I read that the range must be the base field of the two vector spaces, and I can recall the definitions, but the statement has no significance yet- it's of no consequence. Perhaps that's my biggest problem.
I'm still working
Rachel
diag{ } is a standard way of saying diagonal matrix with these diagonal entries and zero elsewhere.
the n means the dimension of the vector space, and the linear maps are then nxn matrices.
the kernerl of a bilinear map is not a subset of nxn matrices, it is a subset of the vector space the bilinear form acts on.
Okay, I need something more meaningful.
So, vector space R^3 is the set of all 3-tuples (x, y, z) where x, y, z, are in R?
Do I need to say R^3 over R?
The linear maps are then
x, 0, 0,
0, y, 0,
0, 0, z,
or is this the basis? I have no idea.
Rachel
Okay, must call it a day. But I'm not giving up.
Rachel
those are the diagonal linear maps wrt that basis. the linear maps are all 3x3 matrices.
As in
x_1, x_2, x_3,
y_1, y_2, y_3,
z_1, z_2, z_3,
or
x, y, z,
z, x, y,
y, z, x,
or am I thinking of this the wrong way? I really should just sit down with a book and start from vector spaces ;)
Rachel
EDIT- What I mean is, the n-tuples are ordered, how does that order transfer to the matricies?
EDITEDIT- oh, I think I see, x is a column, y is a column, z is a column?
it doesn't appear to be correct. you really ought to stop writing x,y,z for everything in sight as that is suggestive in the wrong direction.
If X and Y are vector spaces over R, b(x,y)=x*y, then the kernel of B:X*Y->R is x=y=0, b(0,y) and b(x,0), i.e., the x and y axes of the cartesian plane?
That is only true if X and Y are 1-dimensional, where did they come from, as you don't use them in the second part of the post? How do you mulitiply two vectors x and y using a * operation?
a bilinear form on V (one vector space, say) is a pairing from VxV to R (if they are real vector spaces, let's not get too complicated).
so it takes two vectors and in a bilinear way yields a real number.
bilinear means b(x+y,z) = b(x,z)+b(y,z) and b(kx,y)=kb(x,y) for all vectors x,y,z in V and all real numbers k, and this is true in second component too.
Examples: the trivial bilinear form b(x,y) = (x^t)y (think of them as column vectors). The kernel of this is 0.
this is just the usual inner product on V. inner products are the most obvious kind of bilinear form.
Here's another one.
b(x,y) = x_1y_1, that is just the product of the first components of the vectors. the kernel of this is then the span of the other basis vectors (all but the first one).
Any bilinear form can be represented as a matrix, A with b(x,y) = (x^t)Ay
write that out and do a few examples by picking V as R^2 and just choosing A at random.
I am making a mistake somewhere- perhaps this will help show where.
I meant them to be one-dimensional, I thought that was understood. ?b(x,y) x is in X and y is in Y?
I meant XxY, the same thing you mean by "VxV"- I wasn't sure what notation to use.
Oh, you say "vectors" so you mean how do I do b(x,y)=x*y? I don't know why that's wrong.
Here's what I don't get. I have the rules for vector spaces, and *think* I understand them- vector addition and scalar multiplication.
Now, (s is scalar, v is vector)
s_1*v_1 + s_2*v_2 + ... + s_n*v_n
is a linear combination, right?
But I don't see how or why you combine them in this way. Why do you add all the scalar products together? :confused: :mad: :confused:
I know I need to read more, and I'm getting a book today.
Rachel
it certainly wasn't understood that X and Y were to be R. At no point do you say that they ought to be.
The left kernel of b a form on XxY is s subspace of X, not of XxY (the cartesian product which isn't even a vector space).
This started off as a thread about symmetric bilinear forms, ie on XxX. as Y is not equal to X (it is isomorphic but not equal) you're doing something different.
i think you ought to at least learn the definitions of these things because you're attempting to run before you walk. as basically you're asking, in the last part, what are the operations in a vector space, why are you allowed to add together vectors? because that's what vectors do.
I know I jumped too far ahead, that's why I said, "Okay, I've jumped too far ahead... thanks for trying." ;)
Your reply encouraged me, but I guess I took it the wrong way.
Anyway, thanks for trying
Rachel
  • · Replies 41 ·
  • · Replies 0 ·
