Solving Angular Velocity of Pulley/Cylinder with Mass M, I, m, h
  • Thread starter Thread starter Clutch306
The discussion focuses on calculating the angular velocity of a pulley and a cylinder system involving a mass M = 4.0 kg solid cylinder and a mass m = 1.0 kg object. Using the conservation of energy principle, the speed V of the falling object after descending a distance h = 1.0 m is determined to be 4.427 m/s. The angular velocity of the cylinder is calculated as ω = 11.067 rad/s, while the angular velocity of the pulley is found to be ω = 44.27 rad/s, utilizing the respective radii of the cylinder (R = 0.40 m) and pulley (r = 0.10 m).
  • Understanding of conservation of energy principles
  • Familiarity with rotational dynamics and angular velocity calculations
  • Knowledge of basic physics concepts such as mass, radius, and gravitational acceleration
  • Ability to manipulate equations involving kinetic and potential energy
  • Study the principles of conservation of energy in mechanical systems
  • Learn about rotational dynamics and the moment of inertia
  • Explore the relationship between linear and angular velocity in rotating systems
  • Investigate real-world applications of pulleys and cylinders in mechanical engineering
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of rotating systems and energy conservation in mechanical contexts.
Clutch306
A uniform solid cylinder of mass M = 4.0kg and radius R = 0.40m rotates about a vertical axis on frictionless bearings. A massless cord is wrapped around the cylinder and passes over a pulley of rotational inertia I = 0.020 kg*m2 and radius r = 0.10m. The free end of the cord is attached to a small object of mass m = 1.0kg. There is no friction on the pulley axis and cord does not slip on the pulley.
(a) What is the speed V of the object after it falls a distance h = 1.0m from rest?
(b) What is the angular velocity of the cylinder corresponding to V?
(c) What is the angular velocity of the pulley corresponding to V?
What is this, the Do-Clutch's-Homework-For-Him Forum?
cookiemonster
(a) To solve for the speed V of the object, we can use the conservation of energy principle. At the beginning, the object is at rest and has potential energy PE = mgh, where g is the acceleration due to gravity. As the object falls a distance h, it gains kinetic energy KE = 1/2mv^2. Therefore, we can set these two equal to each other and solve for V:
mgh = 1/2mv^2
v = √(2gh)
v = √(2*9.8*1.0)
v = 4.427 m/s
(b) The angular velocity of the cylinder can be calculated using the equation ω = v/r, where ω is the angular velocity, v is the linear velocity, and r is the radius of the cylinder. Therefore, we can plug in the values we have:
ω = v/r
ω = 4.427/0.40
ω = 11.067 rad/s
(c) Similarly, we can calculate the angular velocity of the pulley using the same equation ω = v/r, but this time, we use the radius of the pulley:
ω = v/r
ω = 4.427/0.10
ω = 44.27 rad/s
  • · Replies 30 ·
  • · Replies 22 ·
