| Thread Closed |
Tank Draining/Filling problem |
Share Thread | Thread Tools |
| Mar7-08, 12:11 AM | #1 |
A tank contains 90 kg of salt and 2000 L of water. Pure water enters a tank at the rate 12 L/min. The solution is mixed and drains from the tank at the rate 6 L/min. Find the amount of salt in the tank after 1.5 hours. 2. Relevant equations Assorted Calculus stuff. 3. The attempt at a solution rate in = (.045kg per L)(12L per min) = .54kg/min rate out = (y(t)/2000 kg per L)(6L per min) = (y(t))/(333.33) dy/dt = .54 - ((y(t))/333.33) = (180 - y(t))/333.33 int(dy/(180 - y)) = int(dt/333.33) -ln(180 - y) = t/333.33 + C y(0) = 90 So -ln(90) = C -ln(180 - y) = t/333.33 - ln(90) 180 - y = 90e^(-t/333.33) y(t) = 180 - 90e^(t/333.33) y(90) = 62.103 Actual Answer: 70.8661417323 |
| Mar7-08, 04:27 AM | #2 |
rate out Ro=6L/min concentration in Ci=0 Vo(initial volume)=2000 amount of salt in at t=0 x(o)=90 kg concentraton out Co= x(t)*Ro/(Vo+(Ri-Ro)t) so dx/dt=RiCi-x(t)Ro/(Vo+(Ri-Ro)t now solve this one |
| Mar7-08, 06:09 AM | #3 |
| Mar7-08, 10:12 AM | #4 |
This time I tried...
rate in = 0 kg/min rate out = y(t)/(2000 + 3t)(3 L/min) = y(t)/(666.66 + t) dy/dt = -y/(666.66+t) int(dy/-y) = int(dt/666.66+t) -ln(-y) = t/(666.66+t) + C y(0) = 80 So -ln(80) = C -ln(-y) = (t/(666.66+t)) - ln(80) y(t) = -80e^(t/333.33) No luck this way either. (this is a new problem of the same type.) |
| Mar7-08, 10:24 AM | #5 |
| Mar7-08, 10:26 AM | #6 |
| Mar7-08, 10:27 AM | #7 |
| Mar7-08, 10:36 AM | #8 |
Okay, I regened the problem again.
A tank contains `70` kg of salt and `1000` L of water. Pure water enters a tank at the rate `8` L/min. The solution is mixed and drains from the tank at the rate `4` L/min. Find the amount of salt in the tank after 2.5 hours. It's the same concept as the two above, so what was I doing wrong there? |
| Mar7-08, 10:41 AM | #9 |
Rate in Ri=8 L/min Concentration in Ci=0 Rate out Ro=4 L/min Concentration out = x(t)*Ro/(Vo+(Ri-Ro)t) so dx/dt= Ri*Ci- x(t)*Ro/(Vo+(Ri-Ro)t) remember Co depends on the amount of the salt on the tank, and also on the volume of the tank, so Co= x(t)/V, but the volume on the tank V, depends on the initial volume, and also on how the volume is changing over time as we pipe in and out water so, V=Vo+(Ri-Ro)t Do you see your flaws now??? |
| Mar7-08, 10:55 AM | #10 |
Okay...before I try to punch in the problem, does this look right to everyone?
dx/dt = -(x(t)*4)/(1000 + (4)t) Co = x(t)/(1000+(4)t)\ int(dx/-x) = int(dt/(1000+4t)) -ln(-x) = t/(1000+4t) + C y(0) = 70 so -ln(70) = C -ln(-x) = (t/(1000+4t) - ln(70) x(t) = -70e^(t/(1000+4t)) |
| Mar7-08, 10:58 AM | #11 |
Do a substitution: Let u= 2000/3+ t (I hate using approximations to fractions!) so that du= dt and the integral on the right becomes [itex]\int du/u[/itex]. Also the integral of 1/(-y) is -ln|y|. Since y is the amount of salt in the tank, which can't be negative, you should have -ln(y). I think it would be simpler to leave the negative sign outside the integral. |
| Mar7-08, 11:00 AM | #12 |
| Mar7-08, 11:17 AM | #13 |
I'm a little confused as to the integration...do I just take out the negative to get...
x(t) = 70e^(t/(1000+4t)) Here are my integration steps, what exactly did I do wrong? int(dx/x) = int(dt/(1000+4t)) -ln(x) = t/(1000+4t) + C |
| Mar7-08, 11:23 AM | #14 |
your right hand side is not correctly integrated, you are doing the same mistake there!!!!
[tex]\int \frac{dt}{1000+4t}[/tex] let [tex]u=1000+4t, \ \ du=4dt=>dt=\frac{1}{4}du[/tex] so [tex]\frac{1}{4}\int\frac{du}{u}=\frac{1}{4}ln(u)+C[/tex] now go back and substitute for u, what do you get? |
| Mar7-08, 11:26 AM | #15 |
So is this...
x(t) = 70e^(.25ln(1000 + 4t))) The formula I want? |
| Mar7-08, 12:47 PM | #16 |
x(0)=70, right?
[tex]x(t)=e^{C-.25ln(1000+4t)}=Ae^{-ln(1000+4t)^{\frac{1}{4}}}=A(1000+4t)^{-(\frac{1}{4})}[/tex] now [tex]x(0)=70=A(1000+4*0)^\frac{-1}{4}[/tex], what do u get for A? EDIT: i forgot a minus sign on the power, i edited it!!! |
| Mar7-08, 01:10 PM | #17 |
12.45?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Tank Draining/Filling problem
| Draining tank washout test | General Engineering | 17 | ||
| Tank Problem -- Pump at the END? | Advanced Physics Homework | 3 | ||
| water draining problem | Introductory Physics Homework | 8 | ||
| Thermodynamics problem - filling a bottle from reservoir | Introductory Physics Homework | 3 | ||
| cowboy filling trough problem | Introductory Physics Homework | 9 | ||
