| Thread Closed |
Magnetic Field at the Center of a Wire Loop |
Share Thread | Thread Tools |
| Mar7-08, 09:43 AM | #1 |
A piece of wire is bent to form a circle with radius r. It has a steady current I flowing through it in a counterclockwise direction as seen from the top (looking in the negative z direction). What is B_z(0), the z component of B at the center (i.e., x = y = z = 0) of the loop? Express your answer in terms of I, r, and constants like mu_0 and pi. 2. Relevant equations 3. The attempt at a solution I know this equation: [tex]\frac{(\mu_0)I}{2(\pi)r}[/tex] but there is a hint that says I need to find the Integrand. Thank You. |
| Mar7-08, 09:48 AM | #2 |
[tex]\oint \vec B \cdot d\vec r = ?[/tex] |
| Mar7-08, 09:53 AM | #3 |
Mentor
Look up the Biot-Savart law. That will give you the field from a current element. |
| Mar7-08, 10:00 AM | #4 |
Isnt the equation I posted the Biot-Savart law?
| Mar7-08, 10:08 AM | #5 |
Mentor
| Mar7-08, 10:18 AM | #6 |
Sorry, about that, I was looking at the wrong equation in my book.
B = [tex]\frac{\mu_0}{4\pi}[/tex] [tex]\frac{q(v X r}{r^2}[/tex] since its circular motion B = [tex]\frac{qmv}{r}[/tex] <=Would I need to ingetrate this equation? |
| Mar7-08, 12:31 PM | #7 |
Mentor
[tex]d\vec{B} = \frac{\mu_0 I d\vec{\ell}\times \hat{r}}{4 \pi r^2}[/tex] Figure out what that is for a point in the center of the loop, then integrate around the loop. |
| Mar8-08, 09:58 PM | #8 |
[tex]\vec{B} = \frac{\mu_0 I d}{4 \pi r^2}[/tex] and then integrate that? |
| Mar9-08, 07:13 AM | #9 |
Mentor
Almost. After taking care of the vector product, it would be:
[tex]d\vec{B} = \frac{\mu_0 I}{4 \pi r^2}\;d\ell[/tex] Integrate that around the loop. (It's easy!) |
| Mar9-08, 09:29 AM | #10 |
is the [tex]d \ell[/tex] distance*length or the derivative of length.
Then I would [tex]\oint \vec{B} dr[/tex] like Reshma said? |
| Mar9-08, 11:57 AM | #11 |
Mentor
| Thread Closed |
| Thread Tools | |
Similar Threads for: Magnetic Field at the Center of a Wire Loop
| Magnetic Field of wire on rectangular loop | Introductory Physics Homework | 5 | ||
| Magnetic dipole in a loop of wire | Introductory Physics Homework | 3 | ||
| Flux in a Wire Loop w/ a Magnetic Field | Introductory Physics Homework | 1 | ||
| magnetic field at the center of the loop | Introductory Physics Homework | 4 | ||
| Magnetic Field With Loop and Straight Wire Help! | Introductory Physics Homework | 2 | ||
