| Thread Closed |
Conservative Vector Fields -- Is this right? |
Share Thread | Thread Tools |
| Mar7-08, 04:52 PM | #1 |
G = <(1 + x)e[tex]^{x+y}[/tex], xe[tex]^{x+y}[/tex]+2z, -2y> Evaluate [tex]\int[/tex][tex]_{C}[/tex]G.dR where C is the path given by: x = (1 - t)e[tex]^{t}[/tex], y = t, z = 2t, 1=>t>=0 2. Relevant equations 3. The attempt at a solution First, i noticed that there is a scalar potential associated with several terms (not all) in the above vector field: [tex]\varphi[/tex] = xe[tex]^{x + y}[/tex] [tex]\nabla[/tex][tex]\varphi[/tex] = <(1 + x)e[tex]^{x + y}[/tex], xe[tex]^{x + y}[/tex],0> So, i then separated the initial vector field G into two parts: G=<0, 2z, -2y> + <(1 + x)e[tex]^{x + y}[/tex], xe[tex]^{x + y}[/tex],0> First, I compute some derivatives and then evaluate the first line integral: [tex]\frac{dc}{dt}[/tex] = {dx = -te[tex]^{t}[/tex]dt dy = 1dt dz = 2dt} so, [tex]\int[/tex][tex]_{C}[/tex]G[tex]_{1}[/tex] . [tex]\frac{dc}{dt}[/tex]dt = [tex]\int[/tex][tex]^{1}_{0}[/tex]<0, 2(2t), -2(t)> . <-te[tex]^{t}[/tex], 1, 2> = [tex]\int[/tex]0dt = 0 I then computed the second part of G, keeping in mind that this portion of the vector field is conservative. Therefore, i just made a path from point t = 0 to t = 1 with a straight line r, parametrized like so: r = { x = 1-t, y = t, z = 2t} [tex]\frac{dr}{dt}[/tex] = {dx = -1, dy = 1, dz = 2} my second integral then becomes; [tex]\int[/tex][tex]^{1}_{0}[/tex]<(1 + 1 - t)e[tex]^{1 - t + t}[/tex], (1-t)e[tex]^{1-t + t}[/tex],0> . <-1, 1, 2> dt = [tex]\int[/tex][tex]^{1}_{0}[/tex]<(2-t)e, (1-t)e,0> . <-1, 1, 2> dt = So, is my final answer simply this integral evaluated, or am I doing this completely wrong? Sorry if this is a bad question, my book just has no example problems at all, and integrating the theory can be confusing. Any feedback would be appreciated greatly. Thank you |
| Mar7-08, 05:10 PM | #2 |
Recognitions:
That looks like a reasonable approach to me. I didn't check all of the details, though.
| Mar7-08, 05:11 PM | #3 |
The final answer that i got was -e, by computing this integral and adding the two portions (o & -e)
| Mar7-08, 05:11 PM | #4 |
Great, thanks. I don't want anyone to check the details, I just wanted to see if what I was doing was reasonable, or if i was doing it completely wrong.
| Mar7-08, 05:32 PM | #5 |
Recognitions:
I get -e as well.
| Mar7-08, 05:41 PM | #6 |
Thanks a lot, I appreciate the help!
| Thread Closed |
| Thread Tools | |
Similar Threads for: Conservative Vector Fields -- Is this right?
| Conservative vector fields | Calculus & Beyond Homework | 6 | ||
| Singularities and conservative vector fields | General Math | 2 | ||
| Potential function for conservative vector fields | Calculus & Beyond Homework | 5 | ||
| Conservative Vector Fields | Introductory Physics Homework | 0 | ||
| Conservative fields | General Math | 4 | ||
