Differentiating with multiple variables
The discussion revolves around differentiating a function of multiple variables, specifically finding dw/dt for the function w = (x^2 + y^2)^(1/2) where x and y are defined as functions of t. Participants are exploring the application of the chain rule and the use of partial derivatives in this context.
  • Mixed
  • Participants discuss substituting x and y to express w as a function of t alone. There are mentions of using the chain rule and partial derivatives to find dw/dt. Some participants express uncertainty about the differentiation process and the correct application of the chain rule.
There is an ongoing exploration of the differentiation process, with some participants providing guidance on the correct use of the chain rule and clarifying notation. Multiple interpretations of the steps involved are being examined, and while some participants have made progress, there is no explicit consensus on the final outcome.
Participants are working under the constraints of homework guidelines, which may limit the amount of direct assistance they can provide to one another. There is also a mention of a potential misunderstanding regarding the simplification of expressions involving hyperbolic functions.
mattb8818
Find dw/dt. Check result by substitution and differentiation
w = (x^2 + y^2)^1/2, x = e^2t , y = e^-2t
dx/dw = x/(x^2 + y^2)^1/2 dy/dw = y/(x^2 + y^2)^1/2
Dont really know where to go with it
One way would be to substitute for x and y, which would result in a function of t alone.
That's the way they suggest to check the answer. They actually do want you to use partial derivatives, mattb8818. Use the chain rule.
Hi matt! :smile:
First, it's not dx/dw and dy/dw, it's t'other way up!:
dw/dx = x/(x^2 + y^2)^1/2 dw/dy = y/(x^2 + y^2)^1/2
Does that help? :smile:
since w is a function of x and y
and x and y are functions of t
the chain rule is
dw/dt = dw/dx dx/dt + dw/dy dy/dt
compute everything above and you're set
an easy way to remember the chain rule is to draw a tree diagram
w
x y
t t
Thanks for the replies
I did it with the chain rule and got
(2xe^2t)/(x^2 + y^2)^1/2 + -(2e^-2t)/(x^2 + y^2)^1/2
The answer is 2(s)^1/2(sinh4t)/(cosh4t)^(1/2)
I don't really understand this solution
Hi matt!
I don't know what you did to get 2(s)^1/2(sinh4t)/(cosh4t)^(1/2). :confused:
Start from that line (which is correct, except you missed out a "y");
then re-write it as:
[(2xe^2t) - (2ye^-2t)]/√(x^2 + y^2)
(this is both to simplify it, and to lessen the risk of making a mistake)
and just substitute for x and y …
so what is the next line? :smile:
[size=-2](btw, if you type alt-v, it prints √ )[/size]​
Ok thanks all
I am glad I atleast did it right. I looked it up and e^x-e^-x/2 = sinh or something like that, but I guess that was my only mistake so I am happy.
  • · Replies 18 ·
