Calculate the value of the equilibrium constant
The equilibrium constant (K) for the reaction 2NaHCO3(s) <--> Na2CO3(s) + H2O(g) + CO2(g) at 110.0 degrees C can be calculated using the total pressure of the gases at equilibrium, which is 1.648 atm. Since solid sodium bicarbonate has negligible vapor pressure, it is treated as a constant and does not appear in the equilibrium expression. The equilibrium constant will only include the partial pressures of the gaseous products, H2O and CO2, derived from the total pressure.
  • Understanding of chemical equilibrium concepts
  • Knowledge of equilibrium constant expressions
  • Familiarity with gas laws and partial pressures
  • Basic thermodynamics related to phase changes
  • Calculate the partial pressures of H2O and CO2 from the total pressure of 1.648 atm
  • Learn how to derive equilibrium constant expressions for reactions involving solids and gases
  • Study the impact of temperature on equilibrium constants
  • Explore the concept of vapor pressure in relation to solids
Chemistry students, educators, and professionals involved in chemical equilibrium studies, particularly those focusing on gas-solid reactions and thermodynamic calculations.
fk378
The total pressure of gases in equilibrium with solid sodium hydrogen carbonate at 110.0 degrees C is 1.648 atm, corresponding to the reaction
a) Calculate the value of the equilibrium constant at 110.0 degrees C.
I don't know how to begin this because I don't know how to find the initial partial pressure of sodium hydrogen carbonate. How am I supposed to use P total at equilibrium in this problem?
The solid sodium bicarbonate has negligible vapor pressure at 110 degrees C. We usually treat solids as constants, which we then divide out of the equilibrium constant; the only terms you should be left with in your expression for K are from gaseous water and gaseous carbon dioxide.
This approach for dealing with solids holds true in general, unless the equilibrium being studied occurs in a solid solution (e.g., molten rock.)
