Determining an expression for an entropy equation
The discussion focuses on calculating the entropy of mixing for two monatomic ideal gases, A and B, with an arbitrary proportion. The derived expression for the change in entropy due to mixing is given by delta(S) mixing = -Nk[x ln x + (1-x) ln (1-x)]. The total entropy change is represented as delta(S(total)) = delta(S(A)) + delta(S(B)) = 2Nk ln 2. Key considerations include the variable fraction x of species B and the assumption that both gases expand into the total volume, utilizing the Maxwell relation for entropy change.
  • Understanding of thermodynamics, specifically entropy concepts.
  • Familiarity with ideal gas laws and monatomic gas behavior.
  • Knowledge of Maxwell relations in thermodynamics.
  • Basic proficiency in calculus for manipulating equations.
  • Study the derivation of the entropy of mixing for different gas mixtures.
  • Learn about the implications of the Maxwell relations in thermodynamic systems.
  • Explore the behavior of ideal gases under varying conditions using the ideal gas law.
  • Investigate the role of entropy in spontaneous processes and equilibrium states.
Students and professionals in physics, particularly those studying thermodynamics, as well as researchers focusing on statistical mechanics and entropy calculations in gas mixtures.
Benzoate
Calculate the entropy of mixing for a system of two monatomic ideal gases, A and B ,whose relative proportion is arbitrary. Let N be the total number of molecules and let x be the fraction of these that are of species B. You should find
delta(S) mixing=-Nk[x ln x +(1-x) ln (1-x)
delta (S(total))=delta(S(A)) + delta(S(B))=2Nk ln 2
S=Nk[ln((V/N)(((4*pi*m*U)/3Nh^2)^(3/2))+2.5]
according to my thermal physics text, delta(S(A))=Nk ln 2 . The problem says that in species B , x is just a fraction of N. Then , I think I would have to conclude that delta(S(B))=x/N*(k)*ln(2).
so would my expressison be :delta(S(mixing))=delta(S(A))+delta(S(B))=Nk ln 2+ xk/N*(ln(2))
You can't apply [itex]\Delta S_A=Nk\ln 2[/itex] to the general problem; that's the increase in entropy for a single gas expanding into twice its original volume. If [itex]x[/itex] can vary, there's no reason to assume the volume doubles.
Also, remember that as [itex]x[/itex] increases, there are no longer [itex]N[/itex] molecules of gas A but rather [itex](1-x)N[/itex].
One common way to show your desired relation is to assume that each gas expands from its original volume into the total volume and to use the Maxwell relation
[tex]\left(\frac{\partial S}{\partial V}\right)_T=\left(\frac{\partial P}{\partial T}\right)_V=\frac{nR}{V}\quad[/tex]
[tex]dS=\frac{nR}{V}\,dV[/tex]
to calculate the change in entropy.
