Potential Energy and Conservation of energy
The discussion revolves around the work required to stretch a spring, specifically comparing the work needed to stretch a spring by 1 cm versus 2 cm. The subject area includes concepts of potential energy and the properties of springs, particularly Hooke's law.
  • Conceptual clarification, Mathematical reasoning
  • Participants explore the relationship between the amount of work done and the extension of the spring, with one participant suggesting that the work for 2 cm is twice that for 1 cm. Another participant challenges this assumption, indicating a misunderstanding of the underlying principles.
The discussion is ongoing, with some participants providing clarifications about the potential energy formula for springs and the implications of Hooke's law. There is an active exchange of ideas regarding the mathematical relationships involved.
Assumptions about the springs being identical and Hookean are noted, which may influence the interpretations of the work done in stretching the springs.
msattar07
How does the work required to stretch a spring 2cm compare with the work required to stretch a spring 1 cm?
i think its twice the work
Assuming that the two springs are the same and Hookean, you are wrong.
P.E. of a spring is 1/2kx^2 , which is directly proportional to the square of extension from the natural length
you can derive the expression for the potential energy of the spring by integrating the hooke law over the distance moved.
  • · Replies 20 ·
