Find General & Implicit Solutions for dy/dx = e^-3y cos x (1+sin x )^2
The problem involves finding the general and implicit solutions to the differential equation dy/dx = e^-3y cos x (1+sin x )^2, which falls under the subject area of differential equations.
  • Participants discuss attempts to derive a general solution and an implicit form, with some questioning the validity of the original poster's expressions and calculations. There is a suggestion to clarify the separation of variables and integration steps involved.
The discussion is ongoing, with participants providing feedback on the original poster's attempts and questioning certain assumptions. Some guidance on integrating the left side and using substitution for the right side has been offered, but no consensus has been reached on the correctness of the proposed solutions.
Participants express uncertainty regarding the complexity of the mathematics involved and the correctness of the derived equations. There is a noted need for clarity in the calculations presented.
morbello
im asked to find the general solution to the equation below and after find the implicit form I've done some work on it and just wanted to see if I am going in the right direction.
the equation
dy[tex]/dx = e^-3y cos x (1+sin x )^2[/tex]
My attempt at a general solution
1[tex]/3 e^3 = (sin x +1)^3 = y =e^3/(sin + 1)^3 +c[/tex]
and the implicit form as
1[tex]/12 (1+sin x )^3/exp (3y)[/tex]
this is harder maths than I've done so not as sure as with most.
the equation
Do you mean
[tex]\frac{dy}{dx}= e^{-3y}cos x(1+ sin x)^2[/tex]?
Surely you don't mean this- it makes no sense. That says that y is a constant, that it is equal to (sin x+ 1)3, and that it is equal to e3 over a constant!
That last is not even an equation!
If you meant
then it separates into
[tex]e^{3y}dy= cos x (1+ sin x)^2 dx[/itex]<br /> The left side integrates easily and the substitution u= 1+ sin x makes the right side simple.[/tex]
no what i ment that y was equaled to
e^3/(sinx+1)^3 +c
the equation
The second eqn doesn't follow from the first. How did you get it? Show the calculation.
Look again at where you got the problem from. What HallsofIvy says makes the most sense.
  • · Replies 16 ·
  • · Replies 29 ·
