Thread Closed
Expected value on subset of Pareto
Share Thread Thread Tools
Mar12-08, 12:37 PM   #1
xag
Hi -
I have a Pareto distribution X (xm=1, k known)*. High-value samples are filtered out and I want the expected value of the remaining. Namely: E[X|X<a].
*Wikipedia notations
Many thanks in advance.
Xavier
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Mar13-08, 09:30 AM   #2
What is the definition of the conditional expectation you are referring to? How did you try to calculate it? Where did you get stuck?
Mar13-08, 10:47 AM   #3
xag
Hi Pere -
What I'm looking for is a mean value.
I found out that the samples of interest belong to a larger set that roughly follow a Pareto distribution, and that among this larger set, the samples of interest are the ones whose values are below a certain number, 'a'.
I can estimate the parameters of the Pareto once for all, and calculate 'a' for each run. But I can't access the samples for each run, so if there was a way to predict it with 'k' (the Pareto shape) and 'a', that would be great.
My first guess is that the samples of interest also follow a Pareto, but I've not shown that. And in this case, could we express its shape K and scale Xm? Then the mean I'm looking for would be K Xm/(K-1).
Best regards,
Xavier
Mar14-08, 02:07 PM   #4
xag
Ok. It seems I got all the way to the finish line and stopped just before :
I guess I just had to integrate the probability density function between 1 and a (it's defined between 1 and +oo).
It gives : (a ^(1 - k) - 1) * k / (1 - k)
Can anyone confirm?
Mar15-08, 01:19 PM   #5
Quote by xag View Post
I guess I just had to integrate the probability density function between 1 and a.
Can anyone confirm?
What you did gives you the probability of a sample with value less than a.
Try the following instead: First calculate the conditional distribution function[itex]\mathbb{P}(X\leqx| X \leq a)[/itex].
By definition this is equal to
[tex]
\frac{\mathbb{P}(X\leq x \wedge X \leq a)}{\mathbb{P}(X\leq a)}
[/tex]
(You already calculated the denominator.)
You can also easily calculate the numerator. For x>a the numerator is [itex]\mathbb{P}(X \leq a)[/itex] which cancels with denominator giving one. For x>a you calculate it in the same way as you did for [itex]\mathbb{P}(X \leq a)[/itex] with a replaced by x. Then you take the derivative with respect to x to find the conditional density function [itex]\rho_a(x)[/itex] (suported on [1,a]), which you then use to calculate the conditional expectation as
[tex]\mathbb{E}\left[X|X\leq a\right]=\int_1^a{x\rho_a(x)dx}[/tex]
A more direct though maybe less obvious formula would be
[tex]\mathbb{E}\left[X|X\leq a\right]=\frac{\int_1^a{x\rho(x)dx}}{\int_1^a{\rho(x)dx}}[/tex],
where [itex]\rho(x)[/itex] is the density function of your original Pareto distribution.
I suggest you try them both and check if they really are the same
-Pere
Mar15-08, 06:10 PM   #6
xag
Can anyone confirm?
Forget this post: the thing I integrated was x * dF(x) and moreover the result I gave here is wrong.
Mar15-08, 06:17 PM   #7
xag
Quote by Pere Callahan View Post
-Pere
Thank you so much.
In both cases I find [tex] \mathbb{E}\left[X|X\leq a\right]= \frac{k}{k - 1} \frac{a ^ k - a}{a ^ k - 1}[/tex]
Thread Closed
Thread Tools
Similar Threads for: Expected value on subset of Pareto
Thread Forum Replies
subset vs proper subset? Set Theory, Logic, Probability, Statistics 22
subset and proper subset Set Theory, Logic, Probability, Statistics 6
The Pareto and Exponential Distr. Where is the mistake? Calculus & Beyond Homework 2
Expected Value, Expected Variance,covariance General Math 0
Pareto Heavy Tailed Distribution Set Theory, Logic, Probability, Statistics 0
