What is the answer to Problem 1 part c in Statistical Mechanics 6.1?
The discussion revolves around Problem 1 part c from a Statistical Mechanics assignment, specifically focusing on the number of variables required to fully describe the state of a system of dipoles. Participants are exploring the relationship between macroscopic and microscopic states in statistical mechanics.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the implications of specifying only the z components of the dipoles and question whether this is sufficient to determine the complete microstate of the system. There are attempts to clarify the distinction between macrostates and microstates, with references to the necessary number of variables to describe the system.
The conversation is active, with participants providing insights into the nature of microstates and the requirements for fully specifying the system. Some have acknowledged a shift in understanding regarding the distinction between thermodynamic and microscopic states, while others are seeking confirmation of their interpretations.
There is an ongoing examination of the assumptions regarding the number of variables needed, with specific reference to the constraints of the problem and the definitions being used in the context of statistical mechanics.
ehrenfest
[SOLVED] statistical mechanics 6.1
http://ocw.mit.edu/NR/rdonlyres/Physics/8-044Spring-2004/00E63135-AD4E-4F76-9917-349D5439ABF4/0/ps6.pdf
The answer to Problem 1 part c is 2N. I disagree. I think it should be N because if you specify the z component of the system then you know both of the macroscopic quantities M and E.
anyone?
If you specify only the z component, you have lost information about the number of equivalent states that would give the same M and E. This is key stat mech information. There is only one state with z = [itex]\mu[/itex], but many with z = 0.5[itex]\mu[/itex], and you need to differentiate them. Providing another distance coordinate (or alternatively, an angle) accomplishes this.
Looking at it another way: two variables are sufficient to describe a line's orientation. With N lines/dipoles, you need 2N variables to describe all the states.
What line are you talking about?
A dipole is like a line segment, in that rotation around the axis of its length is undetectable and does not constitute a degree of freedom.
I don't understand. What "key stat mech information" can you not get if you have all of the z components. If you have all of the z-components, then you know M, E, and can calculate [itex]\Omega[/itex] with the given equation. What else do you want?
You want the number of possible microstates that would result in those macrostate values of M and E. This is the fundamental idea of stat mech: We want to know the probability distribution of microstates that are compatible with our macrostate constraints.
This doesn't seem to be sinking in, so let's go back to the original question: "How many microscopic variables are necessary to completely specify the state of the system?" You give me a z value for each of the N dipoles. But you can't quit there. You haven't completely specified the microstate yet, since the dipoles can rotate in three dimensions and I don't know any of the x values.
I understand that you cannot completely specify the microstate of the system by providing only the z components. It is clear that there are 2N variables needed to specify the microstate of the system.
I think I see the flaw in my thinking now. By "state" in the question they really mean "microscopic state" not "thermodynamic/macroscopic state". Specifying only the z components of the system WILL determine the thermodynamic/macroscopic state of the system by the equations they provide, however, the microscopic state will still be ambiguous. Please confirm that this is correct.
Sounds good.
  • · Replies 18 ·
10K
  • · Replies 54 ·
  • Poll Poll
9K
10K
