Inclined plane and force of friction
The discussion revolves around calculating the force of friction for an object on an inclined plane, given its mass, the angle of the incline, and its acceleration. Participants explore the relationships between forces acting on the object, including gravitational components and frictional forces.
  • Participants discuss the need to identify the components of forces acting on the object, questioning how to determine the number of components necessary for net force calculations. There is an exploration of equilibrium conditions and the implications of constant motion on net force.
The conversation is active, with participants offering insights into the relationships between forces and discussing the implications of constant velocity. Some guidance has been provided regarding the setup of equations, but there is no explicit consensus on all aspects of the problem.
Participants note the challenge of understanding the role of friction without a coefficient of friction or applied force, and there are references to specific examples that illustrate the concepts being discussed.
dranseth
I am having some difficulties finding out the force of friction for an inclined plane. If we know the mass of the object, the angle of the inclined plane, and the acceleration, how to we find Ff?
I know how to draw the diagrams, but I can't seem to find what force of friction is without a coefficient of friction or an applied force.
I am assuming that the object is moving down the plane so that acceleration you have times the mass gives the resultant force down the plane.
The component of the objects weight acts down the plane...and the frictional force opposes this motion(i.e. acts up the plane). Can you now form an equation for the resultant force from these two forces?
That makes sense. How do we know how many components to use for net force in a given problem? I was making this much more complicated than it is..
This is partially because I am teaching this to myself and I came across one question whcihO involved the sum of the applied force, parallel component to the gravitational force, and applied force. I didn't really understand why... It was in equilibrium so the added to equal 0.
When dealing with problems involving inclined planes, spit the weight of the object into its components (One will always be perpendicular to the plane and the other will always be parallel to it acting down the plane).
After you have done that, consider the direction of motion. If the object does not move then the resultant force acting on it is zero. If the object moves down the plane then the resultant force is the sum of the forces acting down the plane(in the direction of motion)- the sum of the forces opposing motion(i.e. up the plane)
Post the question and I will see if I can help you understand it better
You slide a 325N trunk up a 20degree inclined plane with constant motion by exerting a force of 211N parallel to the inclined plane.
what is the sum of the applied force, friction, and the parallel component to the trunks weight? why?thanks in advanced
ok well the resultant force is ma
the component of the 325N against motion is 325sin20
so that ma=211-325sin20-F (F is frictional force)...I hope you reached that far
The question stated that motion was constant. Remember what Newton's first law says about if a body moves with constant motion in a straight line?
net=0
dranseth said:
net=0
Right. so that the net force is zero
so that the sum of the forces is zero. But they did say that there is motion (which is constant). Now if the net force is zero,what does that mean for the acceleration? And hence velocity?
a=0, velocity=constant
Right.So the object is not in equilibrium but is just moving with a constant velocity.
one last question. If I was dealing with a system that contained three blocks attached by a string such as:
and they were accelerating in the right direction, when I am calculating the total frictional force, do I add up all of the normals for the equation Ff=ufn?
Yes you would.
