Why with water on the friction coeffiction is bigger?
  • Context: Undergrad
  • Thread starter Thread starter Orange919
    Friction Water
The discussion centers around the phenomenon of friction coefficients when water is present on surfaces, specifically in relation to static and dynamic friction. Participants explore the implications of water on friction in various contexts, including theoretical and practical applications.
  • Experimental/applied
  • One participant notes that water can act as an adhesive due to the viscous drag of a thin film of water.
  • Another suggests that the experience of slipping on a wet floor relates to aquaplaning, where the interaction with water changes the sliding dynamics.
  • Concerns are raised about the varying coefficients of friction when riding a bicycle on wet surfaces compared to dry ones, indicating that the interaction depends on the surfaces involved.
  • Some participants argue that the lubricating properties of water can be influenced by impurities, such as glycerine, which can alter surface tension and friction characteristics.
  • It is proposed that the amount of water present affects whether it acts as a lubricant or increases friction, with potential mechanisms including sealing cavities and creating vacuum effects.
  • A participant questions the relationship between surface tension and friction, indicating a need for further exploration of this connection.
  • Clarification is sought regarding the type of floor being discussed, specifically whether it is polished, which may influence the observed frictional properties.
Participants express multiple competing views regarding the role of water in friction, with no consensus reached on whether water generally increases or decreases friction under varying conditions.
Participants acknowledge that the effects of water on friction may depend on specific surface characteristics, the presence of impurities, and the amount of water used, which introduces complexity into the discussion.
Orange919
why with water on the friction coeffiction is bigger?
on the corridor floor the static friction is 2.2N, the dynamic friction is 1.4N
when the corridor floor with water on, the friction is increased, the static friction is 3.8N, the dynamic friction is 3.6N
why with water on, the friction coeffiction is bigger?
and, why with water on the difference between static friction and dynamic friction is decreased?
water can't be a lubricator, but oil can. that is because the surface tension and the molecular structure on them. but what is their difference, and why it can cause the difference on the friction coefficient?
thank u
Water can act as an adhesive, probably due to the viscous drag of a thin film of water.
Welcome to PF!
Hi Orange! Welcome to PF! :smile:
I think you're thinking of aquaplaning … when you slip on a wet floor, you're essentially water-skiing rather than sliding on the floor itself.
Wet cloth is definitely stickier than dry cloth.
And whatever is sliding on the floor (like a mop) may absorb some of the water, which will give it different frictional properties anyway. :smile:
Try riding a bicycle on that wet floor and you'll find the coefficient of friction is smaller than with a dry floor. It depends on the two surfaces involved plus the water.
… academic terrorism ? …
Jeff Reid said:
Try riding a bicycle on that wet floor …
Don't let the janitor catch you! :redface:
People have been expelled for less … :smile:
As mentioned earlier, whether water is a lubricant or not depends on the actual surfaces. For, example, it lubricates PEEK pretty well.
Our ordinary experience with water as a lubricant is skewed by impurities in the water which often dramatically change the lubrication properties. For example, add just a small bit of glycerine to water and check the coefficients.
sorry, i know glycerine is a surface active agent, it can decrease the surface tension of the water
but i don't know what is the relations between surface tension and friction
So, pour a cup of water on a tile floor and walk across it. Then repeat, adding a tablespoon of glycerine to the water. Let us know what you find.
It depends on how much water there is between the two surfaces. If water is abundant, it will act as a lubricant because the two surfaces do not slide on each other but on a thin layer of water. But if water is just enough, it will increase the friction for a number of reasons. One of them is that the water seals some possible cavities and creates vacuum which certainly increases the force perpendicular to the surfaces. Others may be adhesion or the likes.
some of the atmospheric pressure, right?
Orange919,
Excuse me. I think I missed something in your post. You said "corridor". Is this a polished floor? If so, you will probably see significant stiction.
  • · Replies 35 ·
