The capacitance of the two metal sphere system
The discussion revolves around determining the capacitance of a system consisting of two metal spheres. The original poster presents a schematic with all necessary variables provided.
  • Participants explore various methods for calculating capacitance, including integration and the use of image charges. Questions arise regarding the choice of integration limits and the uniformity of surface charge density.
The discussion is active, with participants offering different approaches and questioning assumptions. Some guidance has been provided regarding the integration method, but there is no explicit consensus on the best approach.
Participants note the complexity of the problem and the implications of non-uniform surface charge density on the spheres, which may affect the calculations.
Indis Nenhrma
the capacitance of two metal sphere system
What is the capacitance of the two metal sphere system.
*The question has been attached shematically. All the variables are given in the attached file, there is no missing variable.
thx for any help.
I thought that I could solve this problem by integration. I can divide two spheres to small circular plates as parallel to each other and consider them as parallel plates. Then, i can add them up. It ain't difficult, but it requires calculus knowledge.
You can't do it that way. It is a very difficult problem by any method.
You could try image, but a large number of image charges would be needed.
Capacitance of two metal sphere system
You can find the electric-field due to one sphere. Then, intagrate it from r to L-r to find the potential between spheres due to one sphere. I think the spheres must have a charge +Q and -Q, thus, potentials due to each sphere are same and total potential is two times the calculated one with integration. Once you have found an equality consists of Q and V, you can find the capacitancy by writing this equality in form of Q = C*V.
Why did you choose limits as r and L-r?
Because potential diffrence inside a sphere is zero, there is no potential difference between 0 and r, you do not need the to add potential difference between these points. And, of course, electric-field inisde sphere is zero, not depending on distance, so you can not even intagrate electric-field by choosing limits involving 0 to r and L-r to L intervals.
thx dude.
But the surface charge density on each sphere is not uniform.
