Thread Closed
Bullets Per Minute
Share Thread Thread Tools
Mar16-08, 02:41 PM   #1
Bullets Per Minute
This was a two part question, the first part I was able to calculate.
Question Part 1:
A machine gun fires a stream of bullets into a block that is free to move on a horizontal frictionless tabletop. Each bullet has mass 66 grams; their speed is 930 m/sec, and the block a mass of 7.36 kg. After 15 bullets, the speed of the block is?
Calculation Part 1:
[tex]\frac{(0.066 kg * 15 bullets)}{(0.066 kg * 15 bullets) + 7.36 kg}=110.263 m/sec[/tex]
Question Part 2:
If a man in the previous statement can exert an average force of 180 N against the gun, determine the maximum number of bullets he can fire per minute.
Attempt to Calculate:
I am unsure of how I would go about this. I attempted to think of it as a reverse of the previous question, but what didn't work out was getting bullets per minute without figuring out a basic equation then using sample bullets/minute numbers to see where the breaking point of 0 m/sec is. Also, I kept in mind the need to change the velocity of m/sec to m/min if needed.
The equation I attempted to use was:
[tex]V_{gun+man}=\frac{m_{bullet}*numberofbullets}{(m_{bullet}*numberofbulle ts)+M_{man}}v_{bullet}[/tex]
Any help with where to start?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Mar16-08, 02:58 PM   #2
it is basically just a simple problem of conservation of momentum.
Mar16-08, 03:32 PM   #3
You have the "force equation": F*t=m*v
the total momentum during a minute is m*v*k, where k is the number of bullets per minute.
Mar16-08, 04:29 PM   #4
Bullets Per Minute
Quote by Kurret View Post
So I get...
[tex]F \times t=m \times v[/tex]
[tex]F \times t=m \times v \times k[/tex]
[tex]\frac{F \times t}{m \times v}=k; k=bullets/min[/tex]
[tex]\frac{180 N \times 60 sec}{0.066 kg \times 930 m/sec}=175.953 bullets/sec[/tex]
Thank you both.
Mar17-08, 01:13 AM   #5
Quote by blue5t1053 View Post
So I get...
Thank you both.
.953????
Never knew Bullets went to the target in fractions.!!!!!
Mar17-08, 11:15 AM   #6
ever heard of splinters/shotguns/shells
Mar17-08, 12:24 PM   #7
Recognitions:
Homework Helper Homework Help
Part 1 is correct, although your expression is not correct. You need the muzzle velocity in there:
[tex]m_{bullet}v_{muzzle} N_{bullets} = \Delta P = (M_{block} + m_{bullet}N_{bullets}) v_{block/bullets}[/tex]
The analysis for Part 2 is not clear.Since the force applied by the gun to the shooter is the time rate of change of momentum of the gun/bullet system F = dp/dt:
[tex]F = \frac{dm}{dt}v_{muzzle}[/tex]
[tex]\frac{dm}{dt} = F/v = 180/930 = .194 \text{kg/sec}[/tex]
Therefore, the number of bullets per second is .194/.066 = 2.94 or 176 bullets/minute, but this is only if you want to provide an average force of 180 N. The actual peak force that must be applied will be greater than this, so actually firing this number of bullets will cause the force on the shooter to exceed 180N.
AM
Thread Closed
Thread Tools
Similar Threads for: Bullets Per Minute
Thread Forum Replies
Bullets kill General Discussion 24
Lambdas as bullets Computing & Technology 2
(Bullets + you) / e = death, but why? :) Biology 8
Bullets Introductory Physics Homework 8
bullets and truth General Physics 2
