Solving for Lagrangian Forces in Newton's Bucket Problem
  • Thread starter Thread starter int.uition
The discussion focuses on solving the Lagrangian forces in the context of Newton's Bucket Problem, specifically analyzing the arrangement of water in a spinning bucket. The Lagrangian is defined as L = T - U, with kinetic energy T and potential energy U expressed in cylindrical coordinates. Key equations derived include dL/dr, dL/da, and dL/dz, which relate to the forces of constraint. The participants emphasize the importance of applying constraints effectively and correcting the kinetic energy formulation to accurately reflect the dynamics of the system.
  • Understanding of Lagrangian mechanics
  • Familiarity with cylindrical coordinates
  • Knowledge of kinetic and potential energy equations
  • Basic principles of dynamics and forces of constraint
  • Study the derivation of Lagrangian mechanics in detail
  • Learn about forces of constraint in mechanical systems
  • Explore applications of cylindrical coordinates in physics problems
  • Investigate the implications of rotational dynamics on fluid behavior
Students of physics, particularly those studying mechanics, engineers working with dynamic systems, and anyone interested in the mathematical modeling of fluid dynamics in rotating frames.
int.uition
How does the water in a spinning bucket arrange itself, given that its surface must be perpendicular to the force that holds the water? Solve for the Lagrangian forces of constraint.
As a convention, I'm writing position, velocity, and acceleration as such:
position: a velocity: a. acceleration: a..
So here's what I've got so far. We know that the lagrangian is:
L = T - U
I chose cylindrical coordinates, so I got (a is the angle):
T = (1/2) * m * r. + (1/2) * m^2 * a^2 + (1/2) * m * z.^2
U = mgz
Constraint1: m = (pi) * r^2 * h * density
dL/dr = 0, dL/dr. = 0, D/DT * dL/dr. = 0
dL/da = 0, dL/a. = m^2 * a. D/DT * dL/a. = m^2 * a..
dL/dz = mg, dL/z. = m * z. D/DT * dL/z. = m * z..
So for my first equation of motion, solving for motion in the a direction:
0 = -m^2 * a..
Which isn't exactly allowing me to solve for much of anything... where did I go wrong?
I don't really know what type of answer the question is asking for, but here is my attempt on a solution that gives the height y at distance x from the buckets edge along the radius. Not sure if its entirely correct tho.
w=anglespeed(?)
R=radius
a=centripetal acceleration=v^2/(R-x)=W^2*(R-x)
the rake angle b of the water is given by tan b=a/g=(W^2/g)(R-x)
if h is the distance along the y-axis upwards down, for small dx, dh=(W^2/g)(R-x)dx
Integration gives that y=H-(W^2/g)(Rx-(x^2)/2)
where H is the height if the water at the edge of the bucket, ie the maximum height. Its also possible to calculate H in terms of the height of the water in rest, by integrating again and use that the total volyme of the water is constant, but this is sufficient if you only want the shape of the surface.
I am working on this problem as well, as part of my physics class this semester.
I haven't finished it, but I have most of the problem completed. I noticed some mistakes in your work.
First, for finding the langrangian forces of constraint, you want to apply your constraint as late as possible. Also, the equation you'll use to find the forces of constraint is as follows:
dL/dq - D/Dt*dL/dq. + lambda * dQ/dq = 0,
where lambda * dQ/dq = Fq, the force in the q direction. q represents a generalize coordinate.
Your equation for the kinetic energy in cylindrical coordinates is wrong, it is as follows:
T = (1/2) * m * r.^2 + (1/2) * m * (r*a.)^2 + (1/2) * M * z.^2
and U = m * g * z
So then we have
L = T - U = (1/2) * m * r.^2 + (1/2) * m * (r*a.)^2 + (1/2) * M * z.^2 - m * g * z
dL/dr = m * r * a.^2; dL/dr. = m * r.; D/Dt * dL/dr. = m * r..
dL/dr - D/Dt * dL/dr. + lambda * dQ/dr = (m * r * a.^2) - (m * r..) + lambda * dQ/dr = 0
dL/da = 0; dL/da. = m * r^2 * a.; D/Dt*dL/da. = m * (r^2 * a.. + 2 * a. * r.)
dL/da - D/Dt * dL/da. + lambda * dQ/da = -m * (r^2 * a.. + 2 * a. * r.) + lambda * dQ/da = 0
dL/dz = -m * g; dL/dz. = m * z.; D/Dt * dL/dz. = m * z..
dl/dz - D/Dt * dL/dz. + lambda * dQ/dz = -m * g - m* z.. + lambda * dQ/dz = 0
lambda * dQ/dq = Fq, so we solve for the force in each direction:
Fr = m * r.. - m * r * a.^2
Fa = m * (r^2 * a.. + 2 * a. * r.)
Fz = m * z.. + m * g
This is where I am in the problem. These forces are the lagrangian forces of constraint - at this point, you need to factor in the spinning, and then somehow use that to find the shape of the water. I'm basically stuck, at this point.
  • · Replies 27 ·
  • · Replies 20 ·
