Solve Spring Frequency Homework: .88kg to .4kg
  • Thread starter Thread starter jdeakons
    Frequency Spring
The discussion centers on calculating the frequency of a spring-mass system when the mass is altered from 0.88 kg to 0.4 kg. The original frequency is given as 1.8 Hz, and the spring constant K is calculated to be 112.56 N/m using the formula K = (m * 4π²) / P². The confusion arises from the application of the frequency formula, 2πf = √(k/m), leading to a discrepancy in the calculated values for K and frequency. The correct approach involves consistently applying the formulas for frequency and spring constant without mixing variables.
  • Understanding of harmonic motion principles
  • Familiarity with spring constant calculations
  • Knowledge of the relationship between mass and frequency in oscillatory systems
  • Proficiency in manipulating algebraic equations
  • Review the derivation of the spring constant formula K = (m * 4π²) / P²
  • Study the relationship between mass and frequency in oscillatory systems
  • Learn about the implications of changing mass on the frequency of a spring-mass system
  • Practice solving problems involving different masses and their effects on frequency
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators looking for examples of spring-mass systems in action.
jdeakons
A mass of .88 kg when fastened to the lower end of a light-weight spring and set vibrating up and down is found to have a frequency of 1.8 Hz. Calculate the new frequency of vibration when the mass is decreased to .4 kg.
P = 2 [tex]\pi[/tex] [tex]\sqrt{m/k}[/tex]
Using K = (m 4 [tex]\pi[/tex]^2 ) / P^2, my answer for K comes out to 112.56.
But, using [tex]\sqrt{k}[/tex] = ([tex]\sqrt{m}[/tex] 2 [tex]\pi[/tex] )/ P, I get 3.2572. But how can that be? The equations are the same, aren't they? Where am I making the mistake?
Thanks.
[tex]2\pi f=\sqrt{\frac{k}{m}}[/tex]
