Turning effect of forces and min force
The discussion revolves around the concept of moments of forces, specifically in the context of rotational equilibrium and the forces acting on a door. Participants are exploring how to calculate the moment of force X about point A and the implications of determining the minimum force required to prevent the door from turning.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the calculation of the moment of force X and its relationship to the force needed to maintain equilibrium. Questions arise regarding the phrasing of the problem and whether the answers to the two parts of the question are the same.
There is an ongoing exploration of the relationship between the moment and the force required to achieve rotational equilibrium. Some participants suggest that the first part of the question serves as a foundation for answering the second part, while others clarify that the two parts require different types of answers.
Participants note the importance of stating the problem exactly as given and express uncertainty due to missed school attendance. There is also a mention of homework constraints and the need to understand the concepts rather than just provide answers.
tyana21
to find the moment of force X about A,is the working
20x1.4=0.8X
X=35Nm clockwise.
and what does it mean when the question asks "what is the minimum force X that must be applied in order to stop the door from turning?"
does that mean it has to be in equilibrum?
20x1.4=0.8X
X=35Nm clockwise.
X is the force; the moment of the force is just the force times the moment arm (distance to pivot).
The force F exerts a moment tending to turn the door; force X must exert an opposite moment to cancel it.
Yes, rotational equilibrium.
(FYI: It's always a good idea to state the problem exactly as given.)
okay the question is "what is the minimum force X that must be applied in order to stop the door from turning?"
(p.s.,i'm not quite sure as i didnt attend school today and this is part of my homework from my physics workbook)
And you already solved for that force X. :wink: (Even if you didn't recognize it as such.)
oh,i see.but then the question is phrased in two parts.does this mean that i can just bring forward the answer?
What are the two parts? State the complete problem exactly as given.
a) Calculate the moment of the force X about A.
b) what is the minimum firce X that must be applied in order to stop the door from turning?
Good. In the light of my previous posts, can you answer each part?
so does that mean that both questions the answers are the same?
because you previously said that i actually answered the question without me knowing
No, the answers are not the same. The first part asks for a moment; the second part for a force.
Right. You actually solved for the force (X) when you thought you had solved for the moment.
I interpret the first question as a general question that helps you answer the second question. For a force X that is a certain distance from the axis, what's the moment?
so the answer is 28Nm,right?
That's the moment needed to produce equilibrium, but I don't think that's what they are looking for in question a. (They don't even bring up the idea of preventing the door from turning until question b.)
I think they just wanted a general answer. The moment of a force (F) at a perpendicular distance (d) from an axis is Fd. So just plug in what you know about the force X. (At this point, X is just some unknown force. But you do know the distance from the axis.)
ah i see
thanks fr the help!
i got to go now :)
once again thanks!
  • · Replies 35 ·
