What Is the Concept of a Battery and How Does It Work?
  • Thread starter Thread starter asura
    Battery Concept
The discussion centers around the concept of a battery, its function, and related principles in electrochemistry and electric circuits. Participants are exploring the basic workings of batteries, including charge movement and potential difference.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster attempts to clarify their understanding of how batteries generate and move charges, posing specific questions about terminal functions and potential difference. Other participants suggest looking into electrochemical cells for a broader context. One participant raises a question about battery capacity and current output.
The discussion is ongoing, with participants sharing different perspectives and questions. Some guidance has been offered regarding the relationship between batteries and electrochemical cells, but there is no clear consensus on the specific mechanics of charge movement within a battery.
Participants are working with varying levels of understanding and may have different interpretations of battery functionality. There is a noted complexity in the concepts being discussed, particularly regarding electric fields and charge dynamics.
asura
Could someone explain the concept of a battery
I've looked it up in my textbook and wikipedia, but it doesn't really help
Here is what I think I understand
1. Charges (electrons) are made in the cell by chemical reactions
2. They complete the circuit by leaving one of the terminals and returning to the other.
So my questions are
1. Which terminal are the charges made at and which terminal do they leave to go through the circuit?
2. After completing the circuit, how do the charges move from one terminal of the battery to the other?
3. How is potential difference involved in this?
Instead of battery, search Wikipedia for 'electrochemical cell'. A battery is made up of a bunch of electrochemical cells bundled together.
i wn to know about Ah in battery..what is the current produce in 12 V dc at 7 Ah that have been rate 10 hours?
The external electric field of a battery is similar to a dipole. Since a potential difference is created by the battery, the electrons aim for the higher electric potential (or lower potential energy state), and their route would be through the circuitry. Once they reach the battery terminal, they do go through the battery...so its sort of as though the charges run through the circuit while losing energy and reload as the pass through the battery (I'm not sure on how the charges move through the battery). Electric field is propogated by a battery and once the charges start moving in the circuit, you can look at it as an electric field running along the wires/circuitry. Charges do not move fast across a circuit (they actually move at a slow average speed) and the battery does not provide for the charges, it provides for the necessary voltage, which for batteries is called emf; the charges are available at all points in the circuit and the battery provides an electric field that moves the charges (electric fields are able to travel at the speed of light)...so when a circuit is closed by a switch, the reason why the device works seemingly instantly is because the electric field is able to propagate at high speeds and charges at considerably all parts of the circuit start moving almost simultaneously.
  • · Replies 44 ·
  • · Replies 30 ·
