Uncovering the Secrets Behind Amazing Card Trickery
  • Thread starter Thread starter octelcogopod
The discussion revolves around the techniques and methods behind card tricks showcased in specific videos. Participants explore various explanations, including the use of invisible thread and wax, as well as opinions on video editing versus real magic tricks.
  • One participant expresses curiosity about the methods used in the card tricks presented in the videos.
  • Another mentions a tutorial involving a thin string and wax for the first trick.
  • Some participants suggest that the second video may involve poor editing rather than a genuine trick.
  • A participant shares a personal experience with a trick that uses invisible thread and wax, describing the setup and cost.
  • There is a discussion about the visibility of the string in the first trick, with one participant noting how the magician manipulates it.
  • A later reply suggests an alternative method for achieving a floating card effect using inexpensive materials.
Participants do not reach a consensus on whether the tricks are real or edited, and multiple competing views on the methods and effectiveness of the tricks remain present.
Some claims about the tricks depend on assumptions regarding visibility and the effectiveness of the proposed methods. The discussion includes varying levels of certainty about the techniques described.
I've watched a tutorial for the first one but can't find it. It involves a very thin string and some wax to attach it to the top of the card.
Second one looks like a really bad video edit.
Agreed, but the first one looks pretty cool. Not sure if it is an edit or a real trick.
Yeah I kind of picked the wrong video there.
His other card tricks are cool though..
Thanks for the explanation though.
Ok don't tell anyone. I have this trick. Magician’s invisible thread and wax. The Gimmick is attached to your waist. It takes about 2 minutes to set the trick up. You can use business cards or playing cards. The trick is great because you can take a business card from anyone and start twirling in less then a second. Cost is $20.00 dollars. You have to order extra wax. It does take a little practice but you can perform the trick just a few feet from anyone they can't see the thread.
Thats neat. For the first one you can tell that it is attached to a string and he moves it. Even when he goes the other way it is touching his thumb to bring it back. I don't get how he does the first or last swoop over it and under it though?
bassplayer142 said:
Thats neat.
I mentioned a gimmick. You really don't need it, magician wax, invisible thread and scotch tape. Roll the wax in a ball attach it to the thread and card. Attach the other end of the thread to scotch tape then stick it behind your ear. "Wellah" you have a floating card for less then $5.00 dollars. Check this video. he has a gimmick and it's attached to his waist.
http://www.magical-tricks.com/Floatingcardbig1.wmv
  • · Replies 45 ·
14K
  • · Replies 21 ·
  • · Replies 22 ·
  • · Replies 46 ·
9K
