Investigating Complex Series: Convergence or Divergence?
The discussion revolves around the convergence or divergence of the series \(\sum_n \frac{1}{1+z^n}\) where \(z\) is a complex number. Participants explore different cases based on the modulus of \(z\), specifically when \(|z| < 1\) and \(|z| \geq 1\).
  • Mixed
  • Participants attempt to analyze the series by considering the behavior of the terms based on the modulus of \(z\). Some suggest using comparison tests, while others express uncertainty about the validity of their comparisons and reasoning.
The conversation includes various interpretations of the series' behavior under different conditions. Some participants have provided reasoning for convergence when \(|z| > 1\), while others challenge the conclusions regarding divergence when \(|z| < 1\). There is ongoing clarification and questioning of assumptions, particularly around the application of comparison tests.
Participants are navigating complex number properties and the implications of convergence tests, with some expressing confusion over the behavior of the series in different cases. The discussion reflects a mix of attempts to validate their reasoning and requests for further explanation of comparisons made.
ehrenfest
Investigate the behavior (convergence or divergence) of [itex]\sum_n 1/(1+z^n)[/itex] where z is complex.
If the modulus of z is less than 1, it is not hard to show that the limit of the sequence is not 0 (it is actually not finite) and thus the series cannot converge. But if the modulus of z is greater than or equal to 1, I don't what to apply. The root test? The ratio test? The comparison test?
Would you care to show how the series diverges if |z| < 1?
I determined that if |z| > 1, then series converges. I did this by comparing |zn| and |1 + zn| and using the comparison test.
I highly doubt that would work because I used that comparison to show it diverges when |z| < 1. Please explain exactly how you compared the two series.
why don't you show us what you did? it converges for |z| > 1
I will, once I see exactly how you showed that it diverges for |z| < 1.
[tex]|\frac{1}{1+z^n}| \geq \frac{1}{1+|z|^n} \geq 1/|z|^n[/tex]
So the sequence of terms doesn't even go to 0 when |z| < 1
this is wrong 1/(1 + |z|^n) >= 1/|z|^n
for |z| > 1, |1/(1 + z^n)| <= |1/z^n| = |1/z|^n and |1/z| < 1, so we have convergence
for |z| <= 1, suppose we had convergence, then lim n-> inf |1/(1 + z^n)| = 0, so lim 1/lim |1 + z^n| = 0, so lim |1 + z^n| = inf, but |1 + z^n| <= 1 + 1 = 2, a contradiction, so it cannot converge for |z| <= 1
I'm confused now. If Re(zn) < 0, then |zn| > |1 + zn| right? If Re(zn) >= 0, then |zn| < |1 + zn|. I think we have to consider both cases.
edit: you're right in that I made a mistake. Take n = 1, z = -1 + i, then |z| = sqrt(2) and |1 + z| = 1, so |z| > |1 + z|, i forgot these are complex numbers here
By the triangle inequality, |1 + zn| <= 1 + |z|n so
[tex]\frac{1}{1 + |z|^n} \le \frac{1}{|1 + z^n|} = \left|\frac{1}{1 + z^n}\right|[/tex]
and furthermore
[tex]\sum_{n=0}^\infty \frac{1}{1 + |z|^n} \le \sum_{n=0}^\infty \left|\frac{1}{1 + z^n}\right|[/tex]
So by the comparison test, if the LHS diverges, then so does the RHS. Now if |z| <= 1, then 1/2 <= 1/(1 + |z|n) <= 1 for all n and so the limit lies in [1/2, 1] and by the zero-test, the LHS diverges. Thus, so does the RHS.
The problem is this doesn't tell us if the original series of 1/(1 + zn) diverges.
  • · Replies 22 ·
