The discussion revolves around the equations relating wavelength and frequency in the context of wave propagation, specifically addressing the distinction between the symbols \(c\) and \(v\). It also touches on the penetration of different wavelengths through materials, exploring the conditions under which shorter or longer wavelengths may penetrate deeper.
- Technical explanation
- Debate/contested
- Conceptual clarification
- One participant expresses confusion regarding the equations \(f = \frac{v}{\lambda}\) and \(f = \frac{c}{\lambda}\), seeking clarification on when to use each.
- Another participant suggests that \(v\) refers to a particle or wave at any velocity, while \(c\) is specifically for light in a vacuum.
- A question is raised about the applicability of \(c\) when considering other sources of waves, such as the electromagnetic spectrum.
- There is a discussion about the penetration of short versus long wavelengths, with one participant noting that while short wavelengths have more energy, the penetration depth is not universally determined and depends on material properties.
- Another participant challenges the assertion that short wavelengths generally penetrate deeper, indicating that it varies based on material, surface conditions, and frequency ranges.
- A further comment highlights that the transmission characteristics of materials can lead to exceptions, using glass as an example where UV light (shorter wavelength) does not penetrate despite its energy.
Participants do not reach a consensus on the relationship between wavelength, frequency, and penetration depth, with multiple competing views presented regarding the conditions affecting these phenomena.
There are limitations in the discussion regarding the assumptions made about material properties and the generalization of wavelength penetration, which are not universally applicable.
