X in dA => x isolated or strict limit (Topological space)
  • Context: Graduate
  • Thread starter Thread starter NickAlger
    Limit Space
The discussion revolves around the proposition concerning the nature of points in the boundary of a set within a topological space, specifically whether such points are isolated or strict limit points. The scope includes theoretical aspects of topology and the definitions of limit points, as well as the exploration of counterexamples.
  • One participant presents a proposition that if x is in the boundary of A, then x is either an isolated point or a strict limit point of both A and its complement.
  • Another participant questions the reliance on sequences for defining limit points, suggesting that nets could be used instead.
  • A participant expresses uncertainty about the concept of nets and refers to a definition of strict limit points from a source they are using.
  • One participant proposes a potential counterexample involving a topology constructed from an uncountable set and the real line, but later doubts its validity.
  • Another participant suggests using the interval [0, ω1] as a counterexample, noting that ω1 is a limit ordinal and not the limit of any sequence from [0, ω1).
  • Clarifications are sought regarding the notation [0, ω1) and the concept of order topologies.
  • A participant mentions their ongoing search for counterexamples and expresses interest in developing their own ideas.
  • Another participant hints at the cocountable topology on R as a possible counterexample.
Participants express differing views on the definitions and implications of limit points, with some advocating for sequences and others for nets. There is no consensus on the validity of the original proposition or the proposed counterexamples, indicating that multiple competing views remain.
Participants acknowledge limitations in their arguments, particularly concerning the reliance on countability and the definitions of topological concepts. The discussion includes unresolved mathematical steps and varying interpretations of the definitions involved.
NickAlger
I am trying to show the following proposition, but I can only do so in the special case where the basis for the topology is countable. I posted this in the calc & analysis forum and didn't get any responses - I think that this is a more appropriate forum judging by the other posts.
Proposition. If x is in [tex]\partial A[/tex], then x is either an isolated point, or a strict limit point of both [tex]A[/tex] and [tex]A ^{c}[/tex]. ([tex]A[/tex] is a set in a topological space, [tex]\partial A[/tex] is the boundary)
So far, my reasoning is this. Suppose x is not isolated - then let's show that it is a strict limit point of [tex]A[/tex] by constructing a sequence [tex]\left\{ x_{n}\right\}[/tex] in [tex]A[/tex] that converges to x.
If the number of open sets containing x were countable, [tex]\left\{ E_{1}, E_{2}, E_{3}, ... \right\}[/tex], then I would put [tex]x_{1} \in \left(A \cap E_{1}\right) \backslash\left\{x\right\}[/tex], [tex]x_{2} \in \left(A \cap E_{1}\cap E_{2}\right) \backslash\left\{x\right\}[/tex], [tex]x_{3} \in \left(A \cap E_{1}\cap E_{2}\cap E_{3}\right)\backslash\left\{x\right\}[/tex], and so forth.
We know these intersections can't be empty - if [tex]E_{i}[/tex] and [tex]E_{j}[/tex] are open and contain x, then [tex]E_{i}\cap E_{j}[/tex] is also an open set containing x. Since x is not isolated, [tex]E_{i}\cap E_{j}[/tex] must contain some [tex]y \in A[/tex] distinct from x. Thus for a countable number of open sets containing x, we can construct the proper convergent sequence to prove the result.
However, this logic will not work if there are an uncountable number of open sets. I could extend my argument if only the basis is countable, but not to a topology without a countable basis.
Why are you restricting yourself to sequences? There is nothing in the definition of a limit point requiring that it be a sequential limit. In fact, a point x is a limit point of A iff you can construct a net in A\{x} that converges to x.
I'm not really sure what a net is, though from a quick googling it seems to be a generalization of a sequence, so I will look into it.
However, the http://www.ma.utexas.edu/~arbogast/driver.pdf" I'm working from (which could be wrong...) defines a strict limit as follows (page 9),
Definition. A point [tex]x \in \partial A[/tex] is a strict limit point of [tex]A \subset X[/tex] if there is a sequence [tex]\left\{x_{n}\right\}\subset A \backslash \left\{x\right\}[/tex] such that [tex]lim_{n\rightarrow \infty}x_{n}=x[/tex].
If the book is wrong and you need a net to prove the proposition, I would be interested in finding a counterexample for it as currently written.
Ok, I think I might have a counterexample to it as written, but I'm not totally convinced and need to mull it over a bit. Let me run it by yall.
Let Y be a uncountable set and let [tex]\Re[/tex] be the the real line. Construct a basis for the topology of the combined sets as follows: 1) All singleton points in Y are in the basis. 2) The standard metric basis for [tex]\Re[/tex] is in the basis.
Basically we are joining a set with the discrete topology together with the real line. I think this works. Edit: no it doesnt
Now, if [tex]J[/tex] is the interval [tex]\left( -\infty,1\right)[/tex], then [tex]\overline{J}[/tex] is still [tex]\left( -\infty,1\right][/tex] (?), and [tex]\overline{J_{c}}[/tex] is [tex]Y \cup \left[1,\infty\right)[/tex]. Thus [tex]\partial J[/tex] is [tex]\left\{1\right\}[/tex], which is not an isolated point.
Consider the uncountable number of open sets [tex]\left\{1, y\right\}[/tex] Edit: These actually aren't open )-: for all points [tex]y \in Y[/tex]. These all intersect each other only at the single point 1, so there is no way you could construct a sequence that would get them all.
(Edit: changed from [0,1) to all reals.)
Edit2: Wait actually there is a problem with this counterexample, it doesn't work.
How about [itex][0, \omega_1][/itex], where [itex]\omega_1[/itex] is the first uncountable ordinal? [itex]\omega_1[/itex] is in the boundary of of [itex][0, \omega_1)[/itex]. However, it's not an isolated point (it's a limit ordinal), and it's not the limit of any sequence coming out of [itex][0, \omega_1)[/itex] (easy to prove).
I'm not sure you mean by [tex][0, \omega_1)[/tex]. Could you elaborate?
Are you familiar with order topologies? [itex][0, \omega_1)[/itex] denotes the set of all ordinals strictly less than [itex]\omega_1[/itex].
I am new to topology and have not read about that yet. I'll look into it, thanks.
So far my search for counterexamples has been mostly with variations on discrete topologies, I think I am close to coming up with an example of my own that works, so I'm going to keep thinking about my own ideas for a bit.
I think I managed to come up with another example that doesn't involve ordinals or anything exotic. I can give you a hint if you want.
Thanks, but not right now. Maybe in a day or so if my current strategy doesn't pan out.
Heh, my counterexample has somehow managed to morph into something basically equivalent to [0,w1). I'd be interested in hearing a hint about the other example you mention.
Try the cocountable topology on R, i.e. the topology whose proper closed sets are precisely the countable subsets of R.
  • · Replies 25 ·
  • · Replies 58 ·
