| Thread Closed |
pressure change and area ratio help |
Share Thread | Thread Tools |
| Mar22-08, 11:51 AM | #1 |
so if you put about 120 psi in a container and then instanly release it into another with something blocking the way, how fast would that escape, what are the variables in this
| Mar22-08, 01:05 PM | #2 |
Mentor
Size of the containers and size of the orifice.
| Mar22-08, 04:49 PM | #3 |
do guys know any good barrel to air container ratios or anything i should know befor i go building a spud gun cuz i want maximum velocity out of it with like 120 psi
| Mar23-08, 12:01 PM | #4 |
Recognitions:
Unless you can make a C-D nozzle, you'll probably end up choking the valve on the tank and that will set your max velocity.
| Mar25-08, 09:07 PM | #5 |
Mentor
I forgot about choked flow, but in any case, a C-D nozzle still involves choked flow...(i know you know that). If he only cares about mass flow, getting a supersonic airstream doesn't actually do anything for him.
| Thread Closed |
| Thread Tools | |
Similar Threads for: pressure change and area ratio help
| Mach Number as a Function of Area Ratio | Mechanical Engineering | 9 | ||
| A change in length ratio question | General Math | 2 | ||
| Change in area due to relative motion | Introductory Physics Homework | 6 | ||
| Engine experts, how does rod ratio effect how much pressure is applied to cyl. walls? | Mechanical Engineering | 20 | ||
| Pressure = Force/Area | Introductory Physics Homework | 9 | ||
