What is the area under the astroid curve?
  • Thread starter Thread starter motornoob101
    Area
The problem involves determining the area enclosed by the astroid curve defined parametrically by the equations x(t) = 8cos³(t) and y(t) = 8sin³(t). The original poster expresses uncertainty regarding the topic of finding areas under parametric curves.
  • Exploratory, Assumption checking
  • The original poster attempts to set up the integral for the area but struggles with the limits of integration and the relationship between the variables. Some participants question the limits used in the integration and suggest that the order of integration may need to be reversed to correct a negative sign in the area calculation.
The discussion is ongoing, with participants providing guidance on the setup of the integral and addressing the original poster's confusion. There is acknowledgment of the original poster's realization of an error in their approach.
The original poster notes a lack of familiarity with the topic, referencing limited coverage in their calculus textbook. This context may influence their understanding and approach to the problem.
motornoob101
[solved]Area under astroid
So this is another one of those parametric questions that I don't know what I did wrong.
Determine the area of the region enclosed by the astroid
[tex]x(t) = 8cos^{3}t[/tex]
[tex]y(t) = 8sin^{3}t[/tex]
[tex]Area = \int y dx[/tex]
Before I start I must admit that I don't have a good knowledge of this topic of area under parametric curves. My calc textbook had half a page on it and just one example so I am rather clueless.
[tex]Area = 2\int^{8}_{0}ydx[/tex] (Instead of doing -8 to 8, I did 0 to 8 since it is symmetric)
Ok, so y is already given so I just need to find dx.
[tex]dx = -24cos^{2}tsint dt[/tex]
[tex]Area = 2\int^{8}_{0}8sin^{3}t( -24cos^{2}tsint dt)[/tex]
[tex]Area = 2\int^{8}_{0}-192sin^{4}tcos^{2}tdt[/tex]
[tex]Area = -384\int^{8}_{0}sin^{4}tcos^{2}tdt[/tex]
[tex]Area = -384\int^{8}_{0}(sin^{2}t)^{2}cos^{2}tdt[/tex]
[tex]Area = -384\int^{8}_{0}( \frac{1-cos(2t)}{2})^{2}(\frac{1+cos(2t)}{2})dt[/tex]
So anyhow.. there were a lot of integration steps and I arrived at
[tex]Area = -24\left[\frac{-1}{3}sin^{3}(2t)+t-\frac{1}{2}sin4t\right]^{8}_{0}[/tex]
When I evaluate that, it gave me -185.5737904 when the answer is suppose to be 75.3982236
Thanks for any help!
Your limits are x=8 and x=0 which is true when you integrate with respect to x. You are integrating with respect to t.
When you make the change in the limits of integration to go with your substituted variable, you'll also find that the order of integration reverses. Reversing the order again to get the integration running in the right direction will take care of the negative sign you're getting for your area.
Hey guys thanks for the help. I figured it a bit earlier that I was doing it entirely wrong heh. Thanks though.
  • · Replies 20 ·
  • · Replies 105 ·
13K
