Showing Continuity of a function
The problem involves demonstrating the continuity of the function f(x) = x/(1+x^2) across the real numbers. The original poster references the formal definition of continuity in their attempt to establish this property.
  • Participants discuss various approaches to proving continuity, including manipulating the expression for |f(x) - f(a)| and considering the implications of choosing specific values for delta. Some participants explore the relationship between continuity and differentiability.
The discussion is active, with participants sharing different methods and questioning assumptions related to the continuity proof. Some guidance has been offered regarding the choice of delta, and there is exploration of the implications of the proof for uniform continuity.
Participants note the significance of the case when a = 0 and the need to ensure that certain inequalities hold true to satisfy the continuity definition. There is also mention of the relationship between differentiability and continuity in the context of the problem.
Physics_wiz
Show that f(x) = x/(1+x^2) is continuous on R
f is continuous at a if for any epsilon > 0, there exists a number delta > 0 such that if |x-a|<delta, then |f(x)-f(a)|<epsilon.
|f(x) - f(a)| = |x/(1+x^2) - a/(1+a^2)|
= |(x-a)(1-ax)/[(1+x^2)(1+a^2)]|
If I can show that the previous is <= |(x-a)(1-ax)/(1-ax)| then I can cancel the (1-ax) and I'll be done right? I'm not even really sure if I started on this the right way, so any help would be appreciated.
one way to try to figure it out...
Let e > 0. Choose d = ...don't know yet...
Suppose |x-a| < d, then
|x/(1 + x^2) - a/(1 + a^2)| = |(x -a + ax(a-x))/((1 + x^2)(1 + a^2))| <= |x-a|/|(1 + x^2)(1 + a^2)| + |ax||x-a|/|(1 + x^2)(1 + a^2)| <= |x-a|/(1 + a^2) + |ax||x-a|/(1 + a^2) <= |x-a| + |x/a||x-a| <= think about what you can say about |x/a|, then try to find a delta that works
this leads to a proof, but there might be an easier way, play with it, goodluck
ok I got it I think. If I set |x-a|<|a|, then |x|-|a|<|a| or |x/a|<2. So the original
|f(x)-f(a)|<3|x-a|. So, if delta = epsilon/3 then the definition given in the first post will be satisfied.
Side note, does that imply uniform continuity since delta depends only on epsilon?
good work, but not quite
first, if a = 0, everything is trivial(you should verify), so say a != 0
so we have stuff <= |x-a| + |x/a||x-a|.
as you pointed out, we need |x-a| < |a|. But we also need |x-a| < e/3, so choose
d = min{|a|, e/3}, then if |x-a| < d (this means we have both |x-a| < d <= e/3 and |x-a|<d <= |a| )
stuff <= |x-a| + |x/a||x-a| < e/3 + 2e/3 = e.
Another method, which may be simpler:
If a function f is differentiable at a point x then it must be continuous at x. Thus, it is enough to show that f is differentiable on the whole real line, i.e. that f '(x) exists for all real x.
  • · Replies 20 ·
  • · Replies 58 ·
