Why are curves in the plane of the form R -> R^2?
  • Context: Graduate
  • Thread starter Thread starter Simfish
    domains
Curves in the plane are defined as functions of the form f: R -> R^2, where R represents the real numbers and R^2 represents the two-dimensional plane. This one-dimensional parameterization allows for the representation of curves using a single variable, typically denoted as s, which corresponds to the distance along the curve. The discussion clarifies that while it is possible to use two parameters, they would not be independent, thus reinforcing the necessity of a single parameter for curve representation. In contrast, surfaces require two parameters, as exemplified by the mapping of latitude and longitude to points on a sphere in three-dimensional space.
  • Understanding of parameterization in mathematics
  • Familiarity with Cartesian coordinates and their applications
  • Knowledge of functions and mappings in multi-dimensional spaces
  • Basic concepts of curves and surfaces in geometry
  • Explore the concept of parameterization in depth, focusing on its applications in curve representation
  • Study the differences between curves and surfaces, particularly in terms of dimensionality
  • Learn about the mathematical representation of surfaces, including functions from R^2 to R^3
  • Investigate the implications of using multiple parameters in mathematical functions and their independence
Mathematicians, geometry enthusiasts, and students studying calculus or differential geometry who seek to understand the foundational concepts of curves and their representations in various dimensions.
Simfish
So here are some functions of the following types...
f: R -> R^2 (curves in the plane)
f: R -> R^3 (curves in space)
f: R^2 -> R (functions f(x,y) of 2 vars)
f: R^3 -> R: (functions f(x,y,z) of 3 vars)
f: R^2 -> R^2 (vector fields v(x,y) in the plane)
The question is - why are curves in the plane of the form R -> R^2? My intuition tells me R^2 -> R^2 (since after all, curves in the plane are based on x and y coordinates...). And R^2 is a cartesian product of two sets. For any curve, I'd expect x AND y input values...
Hi simfish! :smile:
Because a curve can be defined by one parameter - it's one-dimensional.
The parameter could be length, or angle, or anything convenient.
Usually, it's the length, s.
Then f(s) is the position (on a plane or in space) of the point whose distance along the curve is s.
So f maps the real numbers (R) into the plane or space.
You could use two parameters, but they wouldn't be independent.
Essentially, using (x,y) to define a curve in R2 would be using a function from s to (x,y) and then from (x,y) to R2! :frown:
A surface is two-dimensional, and needs two parameters. For example, points on a sphere are specified by latitude and longitude, so the "function for a sphere" in space would be a map from R2 to R3, specifying a point (x,y,z) for every point (theta,phi).
  • · Replies 20 ·
