What are the values of z that satisfy the equation e^z = 1 + sqrt(3)i?
  • Context: Graduate
  • Thread starter Thread starter galipop
    Complex Complex number
The discussion revolves around finding the values of z that satisfy the equation e^z = 1 + sqrt(3)i. Participants explore the concepts involved in solving this equation, including the use of complex numbers and their polar forms.
  • One participant expresses uncertainty about the concept of the equation and seeks guidance.
  • Another participant suggests representing z as x + iy and notes that e^x is the modulus, which is uniquely determined, while y has multiple possibilities.
  • A different participant provides a formula for e^(a+bi) and emphasizes that there are infinitely many solutions to the equation.
  • Further calculations lead to the conclusion that e^x = 2, which is unique, prompting a search for the value of y.
  • Participants discuss finding y using the tangent function, concluding that y = PI/3 + (PI*n) where n is an integer, indicating the periodic nature of the solutions.
  • One participant summarizes the findings, stating that the solution can be expressed in terms of logarithms and polar form, leading to the conclusion that z = log(2) + 2π/3 + 2πn where n is any integer.
Participants generally agree on the approach to solving the equation and the periodic nature of the solutions, but there is no explicit consensus on the final expression for z, as it is presented in different forms by various participants.
The discussion includes assumptions about the properties of complex numbers and logarithms, but some steps in the derivation remain unresolved or are presented with varying degrees of clarity.
Readers interested in complex analysis, particularly those exploring exponential functions and their applications in solving equations involving complex numbers.
galipop
Hi All,
I've been asked to determine the values of z that obey the equation
e^z = 1 + sqrt(3)i
I'm still not sure the concept of this question. Could someone point me in the right direction?
Thanks
z=x+iy, put it in, e^x is then the modulus, and is uniquely determined, y isn't, but you can work out all the possibilities.
well you can use the folowing direction:
e^(a+bi)=(e^a)*( cos(b)+sin(b)i)
Now you need to find a and b according to the result you want.
please notice that there are infinity number of solution to that !
Best
Moshek
Thanks for the info...
So based on the first 2 replies:
e^(x+iy) = 1 + sqrt(3)i
e^x.e^iy = e^x*(cos(y)+sin(y)i) = 1 + sqrt(3)i
therefore e^x = sqrt(1*1 + sqrt(3)*sqrt(3))
so e^x = 2. which is unique.
Now I just need to find y right?
so am I on the right track?
Thanks
Yes, you're on the right track, you need to find the arguments.
ok so next ...
tan(y) = b/a
tan(y) = sqrt(3)/1
y= PI/3
you talked about infinite solutions, so then
y = PI/3 + (PI*n) where n is an integer.
so now is have
x = ln 2
and
y= PI/3 + (PI*n)
so now do I just subsitute x and y into this eqn?
And after all that work, you arrive at: The solution to e^z = 1 + sqrt(3)i
is z= log(1+ sqrt(3)) since log z= log|z|+ arg(z)+ 2πn
That is, 1+ sqrt(3)i, in "polar form" is 2 e^(2πi/3) so
z= log(2)+ 2π/3+ 2πn where n is any integer.
