Proving Limsup h.w. Proofs: Monotonic Increasing Function
  • Thread starter Thread starter aschwartz
    Proofs
The discussion focuses on proving properties of monotonic increasing functions, specifically in the context of limits and cluster points in real analysis. It establishes that if a function f(x) is monotonic increasing and c is a cluster point, then the left-hand limit of f(x) as x approaches c exists. The proof involves demonstrating that the supremum of f(x) as x approaches c from the left is a monotonic decreasing function, leading to the conclusion that limsup f(x) as x approaches c equals L if and only if the left-hand limit equals L. The user seeks assistance with completing the proofs for the second part of the homework statement.
  • Understanding of monotonic functions and their properties
  • Familiarity with limits and cluster points in real analysis
  • Knowledge of supremum and infimum concepts
  • Proficiency in epsilon-delta definitions of limits
  • Study the properties of monotonic functions in detail
  • Learn about the epsilon-delta definition of limits in real analysis
  • Explore the concept of cluster points and their significance in limits
  • Investigate proofs involving supremum and infimum in the context of sequences
Students of real analysis, mathematicians focusing on limit proofs, and anyone interested in the properties of monotonic functions and their applications in calculus.
aschwartz
1. A function f(x) is said to be monotonic increasing in A if for all x1, x2 ∈ A, x1≤x2 implies f(x1)≤f(x2).
Prove that if f(x) is monotonic increasing in R [f: R→R] and c is a cluster point of R then the limit of f(x) as x→c[tex]^{-}[/tex] exists (might be +∞).
2. s(δ) = sup{f(x) :0<|x-c|<δ}
s(δ) is a monotonic decreasing function, hence based on previous result 1, lims(δ) as δ→0[tex]^{+}[/tex] = L[tex]^{+}[/tex], which is defined to be the limsupf(x) as x→c.
Prove:
A. If L[tex]^{+}[/tex] = limsupf(x) as x→c, then [tex]\exists[/tex] a sequence x[tex]_{n}[/tex], such that as x[tex]_{n}[/tex]→c, f(x[tex]_{n}[/tex])→L[tex]^{+}[/tex].
B. If x[tex]_{n}[/tex]→c and x[tex]_{n}[/tex]≠c and f(x[tex]_{n}[/tex])→L then L≤L[tex]^{+}[/tex].
C. Similarly define L[tex]^{-}[/tex] = liminff(x) as x→c. [This is a monotonic increasing function.]
Prove that limf(x) as x→c = L if and only if L[tex]^{+}[/tex] = L[tex]^{-}[/tex] = L.
2. The attempt at a solution
Ok, so this is what I have so far - I was able to get #1, but got stuck with the proofs for #2.
1. If f(x) is monotonic increasing (decreasing) then limf(x) as x→c[tex]^{-}[/tex] exists.
f: R→R
c ∈R
Case 1: (Proving a lefthand limit exists for a monotonic increasing function)
Let L = sup{f(x) : x<c}. We want to show that ([tex]\forall[/tex][tex]\epsilon[/tex]>0) ([tex]\exists[/tex][tex]\delta[/tex]) ([tex]\forall[/tex]x ∈ R) (0<c-x<δ ⇒ |f(x) - L|<[tex]\epsilon[/tex].
Consider the interval (L - <[tex]\epsilon[/tex], L). [tex]\exists[/tex]x[tex]_{1}[/tex], such that x[tex]_{1}[/tex]<c and L - [tex]\epsilon[/tex]<f(x[tex]_{1}[/tex])≤L [because otherwise L is not the sup, but L - [tex]\epsilon[/tex] would be the sup! So therefore, f(x[tex]_{1}[/tex]) must exist in between those two numbers.]
Let [tex]\delta[/tex] = c - x[tex]_{1}[/tex].
[tex]\forall[/tex]x ∈ R if 0<c-x<δ → 0<c-x<c - x[tex]_{1}[/tex] ⇒ x>x[tex]_{1}[/tex], so since f is monotonic increasing f(x)>f(x[tex]_{1}[/tex]).
Then, because L - [tex]\epsilon[/tex]<f(x[tex]_{1}[/tex])<f(x)≤L,
L - [tex]\epsilon[/tex]<f(x)≤L and |f(x) - L|<[tex]\epsilon[/tex].
This is all I have so far! Any help or advice in how to solve part 2 of this problem would be greatly appreciated - thanks so much!
I would just like to note - I think the latex imaging might have messed this up, but all the epsilons in the problem should not be listed as superscripts, but should be aligned normally and the 1 by the x, should be a subscript. Also, I left out the other 3 cases for fully proving part 1, but the proof is the same - it pretty much follows...Thanks!
