Find the total distance traveled by the object
  • Context: Graduate
  • Thread starter Thread starter Leighton
    Distance traveled
The discussion focuses on calculating various properties of an object moving along a curve defined by parametric equations in the xy-plane. The tangent line at the point (4,5) is derived using the slope formula, resulting in the equation y = 3.9x - 15.6. The speed of the object at time t=2 is calculated as 2.3166 using the formula for speed derived from the derivatives dx/dt and dy/dt. The total distance traveled by the object from t=0 to t=1 is determined to be 1.458 through integration. Finally, the position of the object at time t=3 is found to be approximately (0.998, 3.746).
  • Understanding of parametric equations
  • Knowledge of calculus, specifically integration and differentiation
  • Familiarity with the concepts of speed and distance in motion
  • Ability to apply the point-slope form of a line
  • Study the application of parametric equations in physics
  • Learn about integration techniques for calculating arc length
  • Explore the concept of vector functions in motion analysis
  • Review the use of derivatives in determining rates of change
Students preparing for calculus exams, physics enthusiasts, and anyone interested in understanding motion along curves using parametric equations.
Leighton
An object moving along a curve in the xy-plane has position (x(t), y(t)) at time t with dx/dt = cos(t^3) and dy/dt 3sin(t^2) for 0<= t<= 3. At time t=2, the object is at position (4,5).
a. Write an equation for the line tangent to the curve at (4,5).
b. Find the speed of the object at time t=2.
c. Find the total distance traveled by the object over the time interval 0<=t<=1.
d. Find the position of the object at time t=3.
a. I found the slope by 3sin(t^2)/cos(t^3) (t->2)
I get 15.6
so y-5=15.6(x-4)?
b. Sqrt[(x'(t))^2 + (y'(t)^2)]
so I just squared the givens (with t=2)
= 2.3166 ?
c. Integral (0 to 1) Sqrt[(cos(t^3))^2 + (3sin(t^2))^2]
= 1.458
d. Not sure what to do about this part...
haha! Irony... I was doing the same exact test! You ready for the BC exam Leighton? I got this test off from AP Central... they also posted the grading sheet...
part d...
Integral (2 to 3) cos(x^3) dx = [f(3) - f(2)]i = -0.046
Integral (2 to 3) 3sin(x^2) dx = [f(3) - f(2)]j = -0.093
[f(3)-f(2)+f(2)]i=f(3)i=-0.046+4=3.95i
[f(3)-f(2)+f(2)]j=f(3)j=-0.094+5=4.91j
(3.95,4.91) is the final answer... :)
ARG, I was so mad at the first part because I forgot about the parametric equations... that the dx/dt=Vi dy/dt=Vj and V=Vi+Vj, argggggggggg! :) Anyways.
a. The equation for the line tangent to the curve at (4,5) can be found using the point-slope form, where m is the slope at the given point: y - y1 = m(x - x1). Substituting the given values, we get y - 5 = (3sin(4^2))/(cos(2^3))(x - 4). Simplifying, the equation is y = 3.9x - 15.6.
b. The speed of the object at time t=2 can be found using the given formula: speed = sqrt[(dx/dt)^2 + (dy/dt)^2]. Substituting the given values, we get speed = sqrt[(cos(2^3))^2 + (3sin(2^2))^2] = 2.3166.
c. To find the total distance traveled by the object over the time interval 0<=t<=1, we can use the formula for distance: d = integral (0 to 1) sqrt[(dx/dt)^2 + (dy/dt)^2] dt. Substituting the given values, we get d = integral (0 to 1) sqrt[(cos(t^3))^2 + (3sin(t^2))^2] dt = 1.458.
d. To find the position of the object at time t=3, we can use the given position equation (x(t), y(t)) and substitute t=3. This gives us the position (x(3), y(3)) = (cos(3^3), 3sin(3^2)) = (0.998, 3.746).
