| Thread Closed |
[SOLVED] grinding of MoS2 by a ball mill |
Share Thread |
| Mar25-08, 05:41 PM | #1 |
Hello ,
Particle size of exist MoS2 is under 30micron and I have to change them to below one micron by a ball mill. I have to use a plastic vial for my application as a mill. I select 40cc plastic bottle as a mill, 48 number of Al2O3 balls (1gr each), 20cc isopropanol alcohol and 3 gr MoS2. Size of the particles were examined each 5 hr by SEM. Unfortunately after 72 hr particles did not have favourable size and many of the particles had large size. Regarding MoS2 has very soft structure (hardness 1-1.5), why I couldn’t get good result? In the wet milling what is good proportion between balls, powder and the liquid? |
| Mar25-08, 07:34 PM | #2 |
Try n-decane instead of IPA. This reference claims to get nanoscale particles after 10 hrs of milling.
http://www.aist.go.jp/NIMC/publicati.../09/09_15.html Also, I would try a smaller ratio (10-15cc of decane for 3g of MoS2). And finally, you may need to try different bead sizes too. |
| Thread Closed |
Similar discussions for: [SOLVED] grinding of MoS2 by a ball mill
| Diploma Mill? | Academic Guidance | 9 | ||
| Ball grinding machine...help! | Materials & Chemical Engineering | 0 | ||
| Grinding fibre to powder | General Discussion | 12 | ||
| teeth grinding in sleep... | General Discussion | 17 | ||
| How to increase the temperature of the ball mill in the lab? | Materials & Chemical Engineering | 2 | ||
