Calculating Magnetic Field of a Toroid Using Ampere's Law
The discussion focuses on calculating the magnetic field of a toroid using Ampere's Law. The correct formula derived for the magnetic field inside the toroid is B = μ₀NI/(2πr), where μ₀ is the permeability of free space, N is the number of turns, I is the current, and r is the radius from the center of the toroid. It is confirmed that the magnetic field outside the toroid is zero, affirming the properties of magnetic fields in closed loops.
  • Understanding of Ampere's Law
  • Familiarity with magnetic field concepts
  • Knowledge of toroidal geometry
  • Basic algebra for manipulating equations
  • Study the applications of Ampere's Law in different geometries
  • Learn about the magnetic field of solenoids
  • Explore the concept of magnetic field lines in toroidal structures
  • Investigate the effects of varying current on magnetic fields
Physics students, electrical engineers, and anyone interested in electromagnetism and magnetic field calculations.
snipaj9696
Use ampere's law to determine the magnetic field (a) inside and (b) outside a toroid, which is like a solenoid bent into the shape of a circle.
Here is my work..
IS MY WORK CORRECT?
a.) B(2PIr)=MoIenc
and I found that B=MoNI/2pir
b.) the magnetic field is 0 outside the loop
Yes, you are correct.
For future reference we have Homework forums, for such questions where your query may receive more attention.
