Is Composition of Discontinuous and Continuous Functions Always Continuous?
The discussion revolves around the continuity of functions defined piecewise and their compositions. The functions in question are f(x), which is defined as 4 for x ≥ 0 and 0 for x < 0, and g(x) = x², which is continuous for all x. Participants are tasked with determining the continuity of various combinations of these functions.
  • Participants explore the composition of functions, particularly f o g and g o f, questioning how to express the domains and continuity of these compositions. There are inquiries about the implications of piecewise definitions on continuity and the correct interpretation of function values.
Participants are actively engaging with the problem, raising questions about the definitions and properties of the functions involved. Some guidance has been provided regarding the nature of the compositions and the continuity of the functions, but there remains a lack of consensus on certain interpretations and assumptions.
There are discussions about the implications of continuity and the definitions of the functions, particularly in relation to their domains and the behavior of compositions. Some participants express confusion about proving continuity and the application of theorems related to continuous functions.
Necrologist
f(x) = 4 for x > or = 0, f(x) = 0 for x < 0, and g(x) = x^2 for all x.
Thus dom(f) = dom(g) = R.
a. Determine the following functions: f+g, fg, f o g, g o f. Be sure to specify their domain.
b. Which of the functions f, g, f+g, fg, f o g, g o f is continuous
Ok, so for part (a) I am at f o g step, which I say is f(x^2) = 4 for x > or = 0 and f(x^2) = 0 for x < 0.
Question 1. Since f is a function of g(x), then when I restrict it values, do I have to restrict them in terms of x (as given) or in terms of x^2, since it is a f of g(x) now? Would I have to say that f(x^2) = 4 for x^2 > or = 0 and f(x^2) = 0 for x^2 < 0, instead of how I provided above? If I do have to say it in terms of x^2, then x^2 < 0 makes no sense, and the f would not be defined as f(g(x)) < 0?
Question 2. Since the composition f o g from Q1 is not piecewise anymore and starts at 0 and goes to positive infinity, would it make the composition continuous function?
Question 3. I am a little confused on how to prove that f is not a continuous function using limits. Would someone be able to show me a quick example please?
Question 4. If f is not continuous, then I assume that f, g, f+g, fg are not continuous either. But if f o g IS continuous (Q3), then wouldn't it contradict a Theorem that states "If f is continuous at x0 and g is continuous at f(x0), then the composite functions g o f is continuous at x0"?
Thank you for your time.
Did you check that at all? Suppose x= -1. What you have written says that f(1)= 0. Any any case, what you have given looks like a definition of f. You want to write f o g(x)= something. In this case, that is particularly easy, because g(x) is never negative: f o g(x)= f(g(x))= f(x^2)= 4 for all x. Now, if x[itex]\ge[/itex]0, what is g o f(x)= g(f(x))? If x< 0, what is g o f(x)?
No, f is not a function of g(x)! f is defined as a function of x. And, in fact, so are f o g and g o f. But don't confuse those.
No, "it", if you mean f itself, is not "f of g(x)".
There is NO f(x^2), only f(x). Again, don't confuse f o g with f. In fact, f o g(x)= 4 for all x.
f o g is (piecewise) continuous and does NOT "start at 0 and go to positive infinity". f o g is the constant function f o g(x)= 4. That's trivially continuous.
Suppose f(x)= 1 if x< 0, 2 if x[itex]\ge[/itex]0. Then [itex]\lim_{x\rightarrow 0^-}f(x)= 1[/itex] while [itex]\lim_{x\rightarrow 0^+}f(x)= 2[/itex]. Since those are not the same, [itex]\lim_{x\rightarrow 0} f(x)[/itex] does not exist so we do not have [itex]lim_{x\rightarrow 0} f(x)= f(0)[/itex]. f(x) is not continuous at x= 0.
I recommend you not assume that!
No, the theorem says what happens what happens if f and g are continuous- it says nothing about what can happen if either is not continuous.
so for g o f(x) do we have g(f(x))=
g(4)=x^2 for x > or = 0 and g(0)=x^2 for x < 0 ?
And dom(g o f) = {0, 4}?
The graph would be only two points?
Does g(4)= x^2 and g(0)= x^2 make any sense at all? g(4) is a NUMBER, not a variable. You were told that g(x)= x2 so g(4)= 42= 16.
For any x, g o f(x) means g(f(x)). Now your definition of f says that "f(x) = 4 for x > or = 0, f(x) = 0 for x < 0" so that if x>= 0, g(f(x))= g(4)= 42= 16. If x< 0, f(x)= 0 so g(f(x))= g(0)= 02= 0.
g o f(x)= 16 if x>= 0, 0 if x< 0. It's domain is all real numbers.
