Understanding the Lorentz Force
The discussion revolves around the Lorentz force in the context of current-carrying conductors in a magnetic field. The original poster expresses confusion regarding the behavior of positive charge carriers and electrons under the influence of the Lorentz force, particularly how both can result in an upward force despite their opposite charges.
  • Participants explore the implications of charge carrier direction and current direction, questioning how the Lorentz force applies to different types of charge carriers. There is an examination of the relationship between current, charge sign, and the resulting magnetic force.
Participants are actively engaging with the original poster's confusion, providing insights into the nature of current and charge carriers. Some guidance is offered regarding the independence of magnetic force from the sign of charge carriers, while others reflect on the implications for understanding the Hall effect.
The discussion touches on the Hall voltage and its dependence on the sign of charge carriers, indicating a deeper exploration of the topic beyond the initial question about the Lorentz force.
ehrenfest
[SOLVED] lorentz force
Say you a magnetic field perpendicular to the direction of a current. If you consider the current as electrons moving forward then the Lorentz force on the electrons points up (say). But if you consider the current is a lot of positive charge carriers moving backward, then the Lorentz force on the positive charges points up also because the sign of the cross-product and the sign of the charge changes. That makes ABSOLUTELY NO SENSE TO ME because how can the positive charge carriers and the electrons both move up?
because they are moving in different directions.
but the current is moving in the same direction in both cases
Then that's a good thing. It's telling you the magnetic force exerted on the wire just depends on the current, not on the sign of the charge carriers. I don't see why that would bother you. Don't we already know that?
What bothers me is that for a given current, the sign of the charge carriers determine the sign of the hall voltage
http://en.wikipedia.org/wiki/Image:Hall-effect.png
Sure. As you've observed if the charge carriers are negative, they accumulate on the 'up' side of the conductor. If they are positive they also accumulate on the 'up' side. That's two different signs of potential across the conductor.
So, I guess it was just naive to think that the sign of the transverse electric field would depend only on the current not on what is actually carrying the charge. Maybe that is how they discovered that electrons were the ones in motion...
indeed.
  • · Replies 55 ·
