How Are Compression and Expansion Used in Thermodynamics?
Compression and expansion in thermodynamics are crucial for understanding work done by heat engines, where they relate to changes in volume (\Delta V). Compression is defined as a negative change in volume, while expansion is its positive counterpart, depending on the sign convention used. The work done during these processes can be calculated using the formula W = P\Delta V under constant pressure, or through a differential equation for non-constant pressure, expressed as ∫dW = ∫PdV. These calculations assume no energy exchange with the surroundings aside from the force applied on the piston.
  • Understanding of thermodynamic principles
  • Familiarity with the concepts of work and energy
  • Knowledge of pressure-volume relationships
  • Basic calculus for differential equations
  • Study the First Law of Thermodynamics for energy conservation
  • Learn about the Ideal Gas Law and its applications
  • Explore the concept of isothermal and adiabatic processes
  • Investigate real-world applications of heat engines and their efficiency
Students and professionals in engineering, physics, and applied sciences who are studying thermodynamics, particularly those interested in heat engine design and efficiency calculations.
EngNoob
Could anyone tell me what the compression and expansion is used for in a Thermodynamics situation?
What is the notation for Compression and Expansion in a formula?
I am trying to calculate work done by a heat engine.
Thanks
Science news on Phys.org
Compression & Expansion basically relate to a change in Volume i.e. [itex]\Delta V \ne 0[/itex]
Expansion is negative of Compression. Depending on your sign convention, either of them will be positive. Generally, [itex]\Delta V[/itex] is taken as [itex]\Delta V = V_f - V_i[/itex] and hence compression corresponds to a negative [itex]\Delta V[/itex] i.e. [itex]-\Delta V_c > 0[/itex]
Also, if a conservative force is applied for either of the process, the work done for the same [itex]|\Delta V|[/itex] will have the same magnitude.
Under constant pressure, the work done in doing either of the process is given as:
[tex] W = P\Delta V[/tex]
and for non-constant pressure, we express it in a differential equation. Note that here, Pressure will be some function of Volume and may also depend on Temperature which in turn maybe another function of Volume.
[tex] \int^{W}_0 dW = \int^{V_f}_{V_i}PdV[/tex]
This holds only when there is no energy exchange from the system to the surrounding or vice versa in any form other than the force applied on the piston.
  • · Replies 45 ·
  • · Replies 20 ·
