Understanding and Calculating Corrected Speed Values for Air Track Experiments
  • Context: Undergrad
  • Thread starter Thread starter Starcrafty
    Speed Value
The discussion centers on calculating corrected speed values for air track experiments involving a cart affected by air resistance. Participants clarify that a corrected speed value refers to the theoretical speed of the cart in the absence of air resistance. The method proposed involves using two photogates to measure the time taken for the cart to pass each gate, allowing for the calculation of speed at various points. This data can then be used to analyze deceleration and derive the corrected speed value.
  • Understanding of Newton's First Law of Motion
  • Familiarity with air resistance concepts
  • Knowledge of photogate timing systems
  • Basic skills in data analysis and graphing
  • Research methods for calculating theoretical speed without air resistance
  • Learn how to set up and use photogates for timing experiments
  • Explore data analysis techniques for plotting speed versus distance
  • Study the effects of air resistance on motion in physics
Students conducting physics experiments, educators teaching concepts of motion and resistance, and researchers analyzing dynamics in air track settings.
Starcrafty
what does this mean. I am performing an experiment on an air track with a cart that experiences significant air resistance. For this experiment i think i need to assume it goes at a constant speed. I am supposed to design a method that will allow me to calculate a corrected value with 2 photogates. but i have no idea how to do this because i have no idea what a corrected value is or HOW to obtain it. Any insight into this would be very helpful.
I was thiking of measuring time to pass Photogate A and B at different points to get the speeds at the point and plotting for diff distances to get the deacceleration but then how to i get the corrected value
I'm not sure what you mean. You say the cart experiences significant air resistance but then you say you need to assume it goes at constant speed.
I presume you mean Newton's first law, that, unperturbed, a body will continue in uniform motion.
In your case the air resistance is the perturbation, and I think by a corrected speed value you mean it's speed if there was no air resistance.
Is this correct?
  • · Replies 16 ·
