Finding angular frequency in electric circuit
The discussion focuses on calculating the angular frequency in an electric circuit where the phase difference between voltages U_{2} and U_{1} is 180 degrees. The user attempts to derive the angular frequency using Ohm's Law and voltage equations but struggles to establish the relationship between phase difference and angular frequency. Key equations mentioned include U = Z · I and U = \hat{U} cos(ωt + α). The user successfully calculates the idle current and equivalent impedance but requires further guidance on utilizing the phase difference in their calculations.
  • Understanding of Ohm's Law and its application in AC circuits
  • Familiarity with complex impedance in electrical engineering
  • Knowledge of phase difference in alternating current (AC) analysis
  • Basic proficiency in using phasor representation for voltages and currents
  • Study the relationship between phase difference and angular frequency in RLC circuits
  • Learn how to derive angular frequency from impedance calculations
  • Explore the use of phasors in analyzing AC circuits
  • Investigate the impact of different circuit configurations on phase relationships
Electrical engineering students, circuit designers, and anyone involved in analyzing AC circuits and their frequency characteristics.
sodper
At a certain angular frequency, the phase difference between [tex]U_{2}[/tex] and [tex]U_{1}[/tex] is [tex]180^{\circ}[/tex].
a) Calculate this angular frequency
b) Calculate [tex]U_{2}[/tex] at this angular frequency
See the attachment for circuit configuration.
Ohms law: [tex]U = Z \cdot I[/tex]
Voltage: [tex]U = \hat{U} cos(\omega t + \alpha)[/tex]
I can't seem to find the relation between phase difference and angular frequency.
I've tried to compute the equivalent double-pole, separating the coil with voltage [tex]U_2[/tex] from the rest och the circuit, with the following result:
Idle current:
[tex]U_t = \frac{\omega^2 L^2 + Rj\omega L}{R^2 + \omega^2 L^2} U_1[/tex]
Equivalent impedance:
[tex]Z_0 = \frac{\omega^2 RCL - R - j\omega L}{\omega^2 LC - j\omega RC}[/tex]
And from this I've calculated [tex]U_{2}[/tex]:
[tex]U_{2} = \frac{j\omega L}{Z_0 + j\omega L} U_t[/tex]
But as stated, I can't find the relation between angular frequency and phase difference. How do I use the phase difference?
I'm stuck here. Does anyone have a suggestion?
  • · Replies 21 ·
  • · Replies 54 ·
