A Plane, A pulley and two boxes
  • Thread starter Thread starter Divergent13
    Plane Pulley
The discussion revolves around a physics problem involving a plane, a pulley, and two boxes, specifically focusing on determining the minimum and maximum values of mass m1 to prevent the system from accelerating. The problem is situated within the context of mechanics, particularly dealing with forces, friction, and tension in a system involving inclined planes.
  • Mixed
  • Participants explore free body diagrams and the application of Newton's laws to analyze forces acting on the masses. There is discussion about the direction of friction and tension, as well as the conditions under which m1 would slide up or down the plane. Some participants question the assumptions made regarding the values of m2 and the calculations for m1.
Several participants have provided insights into the calculations for minimum and maximum values of m1. There is acknowledgment of differing results, particularly regarding the maximum value, and a recognition of the impact of friction on these values. The discussion is ongoing, with participants seeking clarification and validation of their reasoning.
Participants note that the problem involves specific values for coefficients of friction and a fixed mass for m2, which influences the calculations. There is also mention of the complexity of mechanics as a subject, indicating a challenging learning environment.
Divergent13
Hi everyone here is the picture of the this plane/friction problem.
http://phasedma.com/uploaded/Physics problem.JPG
The question asks what are the minimum and maximum values of m1 in the figure to keep the system from accelerating...
Take µk = µs = 0.50
Ok when drawing my free body diagrams I have come up with this method of solving the problem... tell me if you agree.
The force of friction can either be up or down the slope, if m2 = 0 or sufficiently small, then m1 would tend to slide down the plane. so Ffr would be directed Up the incline.
We know that Newtons second law for the y direction (i chose my xy coordinate axes along the plane-- IE horizontal x being the plane) shows that
Fnormal - m1*g*cos(30) = m1*ay = 0
since there's no y motion Fnormal = m1*g*cos(30)
Now for the x motion... For the first case (smallest m1) f = ma shows that
m1*g*sin(30) - Ftension - Ffr = m1*ax <---- x direction
since we want ax to be 0, we can solve Ftension since that's related to m2.
Since Ffr can be AT MOST µs * Fnormal= µs*m1*g*cos 30 the minumum value m2 can have to prevent motion (ax = 0) is (after dividing by g)
m2 = m1 * sin(30) - µs*m1*cos(theta).
And then finding the max value wouldn't be much more difficult from there since we already set up our equations..
Am I correct here? If you are willing can someone work it --- what range do you get for the mass?
Thanks for you help. Mechanics gets soooo tough!
Some of your thinking seems OK, but you are getting a little mixed up. First of all, your diagram shows m2 (the hanging mass) as being fixed at 5 kg, so I don't know why you are solving for m2!
The smallest value of m1 would just prevent it from sliding up the plane. Taking up the plane as positive, the forces on m1 (I just call it m) are:
-mg sin(30) -μmg cos(30) + T = ma = 0
(note that T must equal 5g)
You can solve this for the minimum value of m.
The maximum value of m1 would just prevent it from sliding down the plane. The forces on m in this case are:
-mg sin(30) +μmg cos(30) + T = ma = 0
You can solve this for the maximum value of m.
The difference between the two cases, as I'm sure you realize, is that the friction acts in different directions.
Interesting, I see why the tension is 5g, and I get a minimum value of 5.35 kg which seems appropriate... but my max value is nearly 75kg!
Is that correct? Or is there something else that we should consider for max value...
I think that's correct. Know that 75 kg also causes more friction.
Thanks urban... but wow-- that is a huge difference.
