What is the relationship between force, momentum, and impulse in a collision?
The discussion focuses on the relationship between force, momentum, and impulse during a collision involving a 4.5 kg ball and a 0.65 kg plastic cube. The total impulse given to the ball is determined by calculating the area under the force vs. time curve, which is essential for understanding momentum transfer. The conservation of momentum is applied to find the horizontal velocity of the ball and the speed and direction of the cube after the collision. The distance both objects travel before hitting the ground is calculated using projectile motion equations.
  • Understanding of impulse and momentum concepts
  • Familiarity with Newton's laws of motion
  • Knowledge of projectile motion equations
  • Ability to plot graphs and calculate areas under curves
  • Learn how to calculate impulse from force vs. time graphs
  • Study conservation of momentum in inelastic collisions
  • Explore projectile motion and its equations in detail
  • Investigate the effects of friction on collisions and projectile motion
Physics students, educators, and professionals in mechanics, particularly those interested in collision dynamics and momentum analysis.
zen123
A 4.5 kg ball initially rest at the edge of a 2.5 m long, 1.5 m high frictionless table. A hard plastic cube of mass 0.65 kg slides across the table at a speed of 20m/s and strikes the ball to leave the table in the direction in which the cube was moving.
At t= 1 sec , F = .5 x10^3
At t= 2 sec , F = 1 x10^3
At t= 3 sec , F = 1.5 x10^3
At t= 4 sec , F = 2 x10^3
At t= 5 sec , F = 2x10^3
At t= 6 sec , F = 2 x10^3
At t= 7 sec , F = 1.5 x10^3
At t= 8 sec , F = 1 x10^3
At t= 9 sec , F = .5 x10^3
At t= 10 sec , F = 0 x10^3
a) Use the time and force to find the total impulse given to the ball
b) Determine the horizontal velocity of the ball immediately after the collision (you can’t assume the collision is elastic)
c) Determine the following for the cube immediately after the collision:
i. Its speed
ii. Its direction of travel (right or left) , if moving
d.) determine the distance between the two points of impact of the objects with the floor
for part a.) i did impulse = momentum = F*t, but i don't think that's right
for part b.) the equation i used was Vif= (m1-m2)/(m1+m2) but this wasn't correct either
for part c.) i used the equation v2f= (2m1)/(m1+m2), which again was wrong
for part d.)to find the distance i used the equation y = v1t + 1/2gt^2 for both distances which again was wrong
a) Regarding your solution, the problem is what F do you use? Instead, plot F vs. t and find the area under the curve. This will be the total impulse and also represents how much momentum was 'given' to the ball by the cube.
b) Now that you have part (a), you can find this and (c) pretty easily using conservation of momentum. Don't try to plug into a formula like you did above - start over from the law of momentum conservation.
Considering that (d) asks for the range of both objects, you already know they will probably both be moving to the right.
d) Both objects will be horizontal projectiles, so the equation you mention will need to be used separately for horizontal and vertical. I'm sure you've solved problems like that before; if you have the correct velocities you should get the answer.
  • · Replies 0 ·
  • · Replies 35 ·
