Solve 3 Chemical Equilibrium Questions & Calculate Kc
This discussion addresses three chemical equilibrium questions related to the calculation of equilibrium constants (Kc) for various reactions. The first question involves the reaction 2NO(g) <-> N2(g) + O2(g) with a given Kc of 24, emphasizing that only one Kc value exists at a specific temperature. The second question compares two temperatures (T1 and T2) with K values of 0.013 and 0.83, respectively, and explores the relationship between temperature and equilibrium concentration of product B. The third question requires calculating Kc for the reaction CO2(g) + H2(g) <-> CO(g) + H2O(g) at 600 degrees Celsius, given specific conditions in a rigid container.
  • Understanding of chemical equilibrium concepts
  • Familiarity with equilibrium constant (Kc) calculations
  • Knowledge of the ideal gas law and reaction stoichiometry
  • Basic thermodynamics, particularly enthalpy changes (ΔH)
  • Study the calculation of equilibrium constants using concentration data
  • Learn about the effects of temperature on equilibrium positions and Kc values
  • Explore the relationship between enthalpy changes and temperature in chemical reactions
  • Practice solving equilibrium problems using the ICE (Initial, Change, Equilibrium) table method
Chemistry students, educators, and professionals involved in chemical engineering or research who require a deeper understanding of chemical equilibrium and Kc calculations.
Maximillien
Hi, I have 3 questions i can't seem to solve anyways thanks in advance.
1) If the equilbrium constant at a cetain temperature is 24 for the reaction, 2NO(g) <-> N2(g) + 02(g). Both of the systems listed below cannon be in equilbrium because at this temperature because there is only one value of Kc.
[NO] = System 1 - System 2
1.06 1.56
[N2]
[O2]
Since the equilbrium constant does not have units it doesn't matter which unit we use for concentration when calculating Kc.
2a) At T1, K=0.013
At T2, K = 083
If 1.00 mole of A is placed in a 1.00L reaction vessel, at which temperature will the amount of B at equilbfrium be higher? Explain your answer.
2b) If delta H < 0, which temperature is higher? T1 or T2? Explain your answer.
3) Use the information below to calculate Kc for the follwing reactiosn at 600 decrees celsius
C02(g) + H2(g) <-> CO(g) + H2O(g)
A gas mixture that consits of equal amounts of Co and H20 was injected into a 1.97 rigid walled container at 600 degreees ceclius until the pressure reached 7.25 atm. When the reaction reaced equilbirum, 0.024 mole Of CO were present.
Thx much.
So...what have you tried so far?
10K
