How do I calculate the force needed for a hydraulic lift?
  • Thread starter Thread starter jrrodri7
    Continuity Force
The problem involves calculating the force required to maintain a load using a hydraulic lift, specifically focusing on the relationship between the areas of the pistons and the forces applied. The subject area is fluid mechanics, particularly the principles governing hydraulic systems.
  • Participants discuss the relationship between force and area in the context of hydraulic lifts, with some suggesting a proportional setup. There are questions about unit conversions, particularly regarding the conversion of area from cm² to m².
The discussion is active, with participants providing guidance on unit conversions and clarifying the setup of the problem. There is a mix of interpretations regarding whether conversion is necessary, with some participants questioning the original poster's understanding of the units involved.
There is a mention of potential confusion regarding the units of area, as participants clarify that both areas are initially given in cm². The original poster expresses uncertainty about the unit conversion process, which is a focal point of the discussion.
jrrodri7
The small piston of a hydraulic lift has a cross sectional area of (2.8 cm^2), and the large piston connected to it has an area of (17 cm^2). What force of F must be applied to the smaller piston to maintain a load of (28000 N)?
A_1 * V_1 = A_2 * V_2
Since the volumes are the same, I set the A * F to be set equal to each other on both sides and solved...but I'm not seeing something in the unit conversion...Idk what to do.
Maybe it would help to think of it as Force/Area. You have the right idea setting it up as a proportion.
You need to convert cm^2 to m^2
Remember that [itex]1cm=10^{-2}m[/itex] square both sides of that and you will get your conversion.
OH it'd be F1/A1 = F2/A2, and you I would have to convert to m^2, by X100 but squaring them? you mean make it into flat out (m)?
[itex]1cm=10^{-2}m \Rightarrow 1cm^{2}=10^{-4}m^2[/itex]..squaring like that to get the conversion.
Why convert, rock.freak667? The units in the area will cancel. OP will be left with just Newtons.
oh both are in cm^2...my bad, I read it wrong, I thought one was in m^2 and the other was in cm^2..No need to convert then.
10K
  • · Replies 19 ·
