Help: Length Contraction and changing Frames
The discussion centers on the concept of length contraction in special relativity, specifically addressing the scenario of a fast-moving train and its interaction with stationary observers. The observer on the platform perceives the train as having expanded to its proper length (Lo) after stopping, while the observer on the train recognizes that the two porters do not kick the train simultaneously due to time dilation effects. This discrepancy in simultaneity between frames is crucial for understanding the relationship between the lengths L and Lo.
  • Understanding of special relativity principles
  • Familiarity with length contraction and time dilation concepts
  • Knowledge of inertial frames of reference
  • Basic mathematical skills for applying Lorentz transformations
  • Study Lorentz transformations in detail
  • Explore the implications of simultaneity in different frames
  • Practice problems involving length contraction with numerical examples
  • Learn about the twin paradox and its relation to time dilation
Students of physics, educators teaching special relativity, and anyone interested in the foundational concepts of modern physics will benefit from this discussion.
Qazzy03
[SOLVED] Help: Length Contraction and changing Frames
Hi i have been learning about length contraction and i thought i understand how it works until i was given this question.
A very fast train of proper length Lo rushes through a station which has a plaform of length L(<Lo).
According to this observer, two porters standing at either end of the platform (distance L apart) kick the train simultaneously, which makes dents in it. When the train stops, the dents are distance Lo apart.
How is the difference between L and Lo explained by:
(a)the observer on the platform?
(b)the observer traveling on the train?
My attempt at a solution
(I have no idea what happens when something is being length contracted in one frame and then goes to another frame where everything is at rest.)
(a)Since the train is no longer under length contraction when it has stopped the observer on the platform will say that the train has expanded in the x direction. To explian the difference between Lo and L.
(b)However the observer traveling on the train will see something different. Since this is in a different frame we know that the two porters will not kick the train simultaneously. also we know because of time dilation that the two porters will have slower clockers than trains clock. making the dents at Lo distance instead of L distance.
Hopefully, someone can help me out with this. Cheers.
I think you have the essential point. In one frame the kicks are simultaneous, in the other frame they aren't. If you really want to learn this try putting actual numbers in. Put the kickers in at t=0 and x=0 and x=1 in the rest frame. Pick a value of v and figure out what goes on the the moving frame. Both scenarios make perfect sense.
Okay, thanks for the reply. I just wasn't to sure what observer (a) would see. If the train would look like it has expanded in length. Its a little hard to comprehended sometimes.
  • · Replies 54 ·
  • · Replies 36 ·
  • · Replies 78 ·
  • · Replies 45 ·
  • · Replies 33 ·
