| Thread Closed |
Cluster Points |
Share Thread |
| Apr1-08, 11:05 AM | #1 |
Cluster Points
Find a sequence whose set of subsequential limits is the interval [0,1]. 2. Relevant equations If the sequence does not repeat itself, then any subsequential limit is a cluster point. 3. The attempt at a solution I've an idea that [itex]|\sin n|[/itex] is a solution to this, but I'm not sure how to prove this. What I need to show is that, since the sequence I've chosen is non-repeating, then every point in the interval [0,1] is a cluster point. That is, if I take any number in [0,1] and am given an epsilon>0, can I always find an infinite amount of members in the sequence in an epsilon neighborhood around the number? This seems to intuitively work since [itex]|\sin n| [/itex] is all over the interval [0,1] (though not necessarily touching every point in the interval), but can this argument be made more rigorous? Any suggestions? |
| Apr1-08, 11:20 PM | #2 |
Recognitions:
What can the rationals in [0,1] do for you?
| Apr1-08, 11:26 PM | #3 |
Recognitions:
|sin(n)| does almost certainly work. But I don't know an obvious proof of this. Maybe think about an easier example though. How about n*sqrt(2) mod 1? That should be 'all over', too, and maybe easier to deal with. Sorry, but I was just going zzzzz and found your post, so I can't give hints right now.
| Apr1-08, 11:27 PM | #4 |
Recognitions:
Cluster Points |
| Apr2-08, 07:18 AM | #5 |
Thanks Dick and Morphism. I feel really silly now - I was trying to make it much too complicated. Obviously, since the closure of [itex]Q\cap [0,1][/itex] is again [0,1], then the subsequential limits of a sequence of rational numbers in that interval (say, in the order given by the Cantor diagonalization process, throwing away those outside the interval) is the interval itself.
As a side note, in my search for information on cluster points, I stumbled upon an article (on JStor, which my university subscribes to, so I won't post the url since most people won't be able to access) that gives a proof that the cluster points of sin n is the interval [-1,1]. |
| Thread Closed |
Similar discussions for: Cluster Points
| set of cluster points being closed | Calculus & Beyond Homework | 6 | ||
| Matlab: Centroid of a cluster of points | Math & Science Software | 1 | ||
| I need a cluster | General Discussion | 0 | ||
| Topology (Boundary points, Interior Points, Closure, etc...) | Calculus & Beyond Homework | 13 | ||
| boiling points, melting points and absorbed radiation Q's | Introductory Physics Homework | 0 | ||
