Reversible adiabatic expansion/compression equal to zero
The discussion revolves around the change in entropy during reversible and irreversible adiabatic processes. Participants explore the reasons why the change in entropy is zero for reversible adiabatic expansions/compressions, while also questioning the implications for irreversible processes.
  • One participant questions why the change in entropy for a reversible adiabatic process is zero, noting that both reversible and irreversible adiabatic processes involve no heat transfer.
  • Another participant explains that while no heat enters or leaves the system in an adiabatic process, irreversible processes create entropy, which distinguishes them from reversible processes.
  • It is suggested that entropy is created whenever a process occurs due to a gradient, and that reversible processes are idealizations where gradients are minimized.
  • A participant inquires about the effects of constant pressure heating on a non-adiabatic system and its impact on the entropy of the surroundings.
  • It is affirmed that heating a system increases the entropy of the system while reducing the entropy of the surroundings, along with creating entropy at the interface due to temperature gradients.
Participants express differing views on the implications of entropy changes in reversible versus irreversible processes, indicating that the discussion remains unresolved regarding the broader implications of these concepts.
Participants discuss the nature of entropy as a state function and the conditions under which it changes, highlighting the complexity of the topic without reaching a consensus on all points.
a9211l
So, I am looking a question about adiabatic expansions and the associated entropy changed.
Why exactly is the change in entropy for a reversible adiabatic expansion/compression equal to zero? The book says its because there is no heat transfer, but for irreversible adiabatic processes, there is also no heat transfer. So no matter what, shouldn't the entropy of the surroundings for an adiabatic process be zero? In terms of the system, since entropy is a state function, why would it matter whether its reversible or irreversible?
Science news on Phys.org
Hi a9211l, these are great questions. First, the adiabatic requirement just ensures that no entropy enters or leaves the system by way of heating. However, in an irreversible process we create entropy. Or it might be better to say it in reverse: when we create entropy through a mechanism like turbulence, the process is irreversible. The system will never spontaneously go back to its orginal state, because entropy always tends to increase in a closed system.
Thus, one answer to your question is that no entropy enters or leaves the system (work is a transfer of energy without an accompanying transfer of entropy), and no entropy is created. Therefore, the system entropy is constant.
So what would create entropy? Entropy is created whenever a process occurs due to a gradient (in charge, temperature, material concentration, etc.). This is how all real process occur: irreversibly. But we might imagine making the gradient very small to reduce the creation of entropy. This idea taken to its limit gives us the reversible process, an idealization in which we imagine the gradient to be exactly zero.
Is this helpful?
yes, that is very helpful. it made sense to me theoretically (idk if that's the right term...), but just needed that physical explanation.
A second question then, if I do a constant pressure heating of some non-adiabatic system, that still changes the entropy in the surroundings, correct?
Yes, heating a system increases the entropy of the system, reduces the entropy of the surroundings, and creates entropy at the interface due to the temperature gradient.
  • · Replies 22 ·
  • · Replies 60 ·
11K
  • · Replies 57 ·
9K
  • · Replies 16 ·
