Where Should Particle C Be Placed to Balance Gravitational Forces on Particle A?
  • Thread starter Thread starter TS656577
    Gravitation Law
The problem involves determining the position of a third particle C on an x-axis to achieve a balance of gravitational forces on particle A, which is influenced by two other particles, A and B. The scenario is set in one dimension, with specific masses assigned to each particle.
  • Participants discuss the forces acting on particle A from particles B and C, questioning how to express these forces mathematically. There are attempts to relate gravitational potential energy to forces, and some participants suggest focusing on forces rather than potential energies.
The discussion is active, with participants exploring different approaches to express the forces involved. Some guidance has been offered regarding the need to consider forces in one dimension and the requirement for the forces to cancel out. There is no explicit consensus on the method to be used yet.
Participants are working under the constraint of a one-dimensional setup and are trying to clarify the roles of the variables involved, particularly regarding the placement of particle C and the absence of a visual representation in the problem statement.
TS656577
One dimension. In Fig. 13-33, two point particles are fixed on an x-axis separated by distance d. Particle A has mass mA and particle B has mass 7.00 mA. A third particle C, of mass 75.0 mA, is to be placed on the x-axis and near particles A and B. In terms of distance d, at what x coordinate should C be placed so that the net gravitational force on particle A from particles B and C is zero?
F=sqrt((GMm)/r^2) Where G=6.67E-11
I know that M=75 and m=7. Multiplying that by 6.67E-11 I got 3.5E-8/r^2. If i set that equal to 0, then I the r to disappear
Here you are going to have two forces on A, the force from B and the force from C.
HINT:
You want the net force on A to be zero:
[tex]\Sigma F = 0[/tex]
Can you write the net force in terms of the force from B and C?
So would it be the gravitational potential energy between A and C plus the GPE of A and B and add them? and set that = to F(theta)? because in the picture, there is no C
Personally, I think it would be more straight forward to work with Forces here and not potential energies. Also, I do not know why you are using a theta variable, which I assume is an angle. All three masses will be on the same line. There is no C in the picture because you need to figure out where to place it so the net force on A is 0 N. That is the problem.
Try answering these questions to start:
Can you give me a formula for the force from B, in terms of the distance d?
If so, then can you give me a formula for the force from C in terms of x, the position you want to find?
If you can do that as well can you write the net force in terms of the above quantities you just found?
The forces need to cancel out. This means that the force of c on a and b on a must be equal and opposite, right? No need to work with angles as G01 said, since you're restricted to one dimension.
11K
