Why Does the Tension in the Lower Rope Not Depend on Mass M1?
  • Thread starter Thread starter tizzful
    Tension
The problem involves two hanging masses, M1 and M2, which are accelerating upwards due to tension in the ropes. The task is to find the tensions in the lower and upper ropes while considering the effects of acceleration and gravitational force.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between the tension in the lower rope (T2) and the mass M1, with some asserting that T2 is independent of M1 due to it being influenced solely by M2's weight. Others explore the calculations for T1 when the system is accelerating, questioning the correct application of forces and the role of M1.
Some participants have provided guidance on the reasoning behind the tension in the lower rope and the forces acting on the masses. There is an ongoing exploration of how to correctly express T1 in relation to the system's acceleration and the weights of both masses. Multiple interpretations of the forces acting on M1 are being discussed.
Participants note that the equilibrium situation is not relevant to the problem at hand, and there is a suggestion to carefully apply Newton's second law to each mass while considering all acting forces. The diagram provided in the original post is mentioned as potentially misleading.
tizzful
Two Hanging Masses (TENSION) :)
Two blocks with masses M1 and M2 hag one under the other. For this problem take the positive direction to be upward and use g for the magnitude of the acceleration due to gravity. The blocks are now accelerating upwads (due to the tension in the strings) with acceleration of magnitude a. find the tension in the lower and upper rope.
F=ma
W=mg
I found the tension in the lower and upper rope when it was stationary and therefore in equilibrium.
T2=M2g
T1=M1g
Then to find the tension when accelerating I just used
T2=Ma+Mg
T1=Ma+M1g+M2g
For some reason it says that the tension in rope 2 does not depend on the variable M1... So I'm just really lost now on which direction to take..
Thanks in advance
Welcome to PF>
While acceleration T2 is the normal force arising only due to the weight of M2.
Hence T2 does not depend on variable M1.
Oh thank you! That clears up the first one but I'm still stuck on the T1 when accelerating. Would I just go T1=(M1+M2)a + (M1+M2)g?
Yes becoz the total downward force acting on T1 while acceleration is the sum of the weights of M1 and M2.
T2=M2g
T1=M1g
That would be correct for M2 but not for T1 (three forces act on M1). In any case, the equilibrium situation is not relevant to this problem.
T2=Ma+Mg
T1=Ma+M1g+M2g
Carefully apply Newton's 2nd law to each mass. Start by identifying all the forces that act on each mass. (Hint: three forces act on M1.)
(The diagram is misleading because it does not show all the tension forces acting on the masses.)
first, solve for the T2.
T2=M1(g)
then, for T1,
since T1 is carrying the M2,
ΣF=ma
substitute ΣF to T2 + M1(g) -T1
so,
T2 + M1(g) -T1= ma (at rest)
T2 + M1(g) -T1= 0
T1=T2 + M1(g)
  • · Replies 33 ·
