How Is the Capacitance of an Axon Modeled as a Capacitor Calculated?
The problem involves modeling the capacitance of an axon as a parallel plate capacitor, taking into account the dielectric properties of the axon membrane. The original poster provides specific values for the dielectric constant, membrane thickness, and plate area, and seeks to calculate the capacitance.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of the capacitance formula and question the values used for electric permittivity and thickness. There is also consideration of unit accuracy and significant figures in the calculations.
Participants are actively engaging with the original poster's calculations, offering insights on potential errors and clarifying the use of dielectric constants. Multiple interpretations of the problem setup are being explored, particularly regarding the correct application of the capacitance formula.
There is mention of the possibility of significant digit issues affecting the results, and some participants question whether the original poster has correctly identified the parameters for the calculation.
themrk
An axon is the relatively long tail-like part of a neuron, or nerve cell. The outer surface of the axon membrane (dielectric constant = 5, thickness = 1 10-8 m) is charged positively, and the inner portion is charged negatively. Thus, the membrane is a kind of capacitor. Assuming that an axon can be treated like a parallel plate capacitor with a plate area of 4.20 10-6 m2, what is its capacitance?
C = k * Eo * A / d
I used C = 5 * 8.85*10^-12 * 4.20*10^-6 / 1*10^-8 = 1.9E-8 F
However this is not the correct answer and I am perplexed as to why. Is Eo not 8.85*10^-12 or is d not just the thickness?
So is this a parallel plate capacitor with with a dielectric in between? If so then you should be able to just use
[tex]C = \epsilon_r C_{vac}[/tex]
where [itex]\epsilon_r[/itex] is the dielectric constant. I think you may have used the wrong electric permitivity.
Maybe your units are incorrect.
I think the permittivity is correct, 8.85e-12 is the vacuum permittivity, and it was multipled by 5, the dielectric constant.
If you are doing this as a web-based problem, it's probably a matter of significant digits. Use more.
  • · Replies 21 ·
