Fish Bowl Optics: Find Power, Focus Length & Magnification
  • Thread starter Thread starter kpl
The discussion focuses on calculating the optical power, focal length, and magnification of a fish viewed through a spherical fish bowl filled with water. The optical power is derived using the formula Optical power = (n1-n2)/(-r), where n1 is the refractive index of water (1.33) and n2 is that of air (1). The focal length is calculated as f' = -n2r/(n1-n2), indicating a virtual image. The magnification power is determined using the formula Magnification Power = -((L-d)/-r), leading to the expression for the distance L between the observer and the optical image of the fish as L = (-n1/r + n2/l).
  • Understanding of optical power and focal length concepts
  • Familiarity with the refractive indices of water and air
  • Knowledge of magnification formulas in optics
  • Basic principles of refraction at a spherical interface
  • Study the derivation of the lens maker's equation for spherical interfaces
  • Explore the concept of virtual images in optics
  • Learn about the application of the thin lens formula in complex systems
  • Investigate the effects of varying refractive indices on optical calculations
Students and professionals in optics, physics educators, and anyone involved in optical design or analysis of imaging systems.
kpl
Q. There is a fish in a spherical fish bowl of radius r filled with water. The fish is at a distance l from the surface of the tank. An observer in air views the fish at a distance d from the tank.
Please see the attachment for the image.
I am supposed to find the optical power and focus length of the water-air interface, the magnification power of the fish tank and an expression for the distance (L) between the obsever and optical image of the fish.
Here are the attempts I have made:
Focus Length = f'=n2/P = -n2r/(n1-n2)
I used f' because I think it is a virtual image?
Magnification Power = -(Image Distance/Object Distance) =-((L-d)/-r)
L=(-n1/r + n2/l)
Can anyone tell me if these are correct or if I am at least going along in the right direction?
Try the refraction at a single surface formula
n1/s+n2/s'=(n1-n2)/r
here, n1=1.33 (water); N2=1 (air)
and note the sign of s should be negative as the fish is not on the incident-light side of the surface.
9K
12K
